Author Topic: shift light  (Read 5052 times)
bandj524
shift light
« on: April 20, 2013, 08:42:18 PM »
what controls the shift light. the reason im asking is when going down the highway at 55-60 mph in 5th gear my shift light flashs.
Re: shift light
« Reply #1 on: April 20, 2013, 09:05:26 PM »
Have you calibrated your speedometer?
Re: shift light
« Reply #2 on: April 20, 2013, 09:46:35 PM »
like he ^ said
mine was doing it all the time, fixed the speedo gear and never seen it again.
Re: shift light
« Reply #3 on: April 21, 2013, 08:54:31 AM »
Isn't there a sensor that tells the ecu you are in 5th so the light doesn't come on?
Re: shift light
« Reply #4 on: April 21, 2013, 09:41:19 AM »
nope, no sensor, what i can tell you is before i had the R&P replaced the light was coming on all the time, once the speedo was accurate didn't see it come on.
bandj524
Re: shift light
« Reply #5 on: April 21, 2013, 11:02:04 AM »
cool thanks for the fast responses ill get it calibrated or is that something that could be done by changing a part?
Re: shift light
« Reply #6 on: April 21, 2013, 11:28:34 AM »
it all depends of your axle ratio and tire size, you can get pretty close matching t-case speedo gear once you calculate by how much is off.
or you can get a dakota digital speedo calibrator, it goes on the signal wire from the sensor and you can increase/decrease the setting to match your actual speed.
Re: shift light
« Reply #7 on: April 21, 2013, 01:13:04 PM »
I like the little calibrator motorcycles use. (One of the members has one)  It's tiny and easy to use.  Though I've been doing the gear thing since forever.
  • Poseur Extraordinaire®
Re: shift light
« Reply #8 on: April 22, 2013, 08:27:13 AM »
I've had great luck with my Dakota Digital...but I needed one since my Jeep hasn't had a speedo gear since almost a year after I bought it.  It sits just inside my door sill so I can reach down while driving to adjust it if necessary.
Re: shift light
« Reply #9 on: May 10, 2013, 11:49:47 PM »
I just took out the light bulb for that light...  It's absolutely worthless to me!
