Author Topic: Wheeling a 4 banger with an auto...  (Read 3663 times)
95yjman
« on: June 06, 2013, 07:37:48 PM »
I'm mostly talking about the 30RH auto behind the 4 bangers... Anybody that wheels their's ever gotten water in it while wheeling?  I hear they are pretty easy to get water in.  I recently got water in mine but I think it was only because I did something stupid and kinda sank the jeep.  Its all fixed for now but it leaves me wondering is water gonna get into this thing while driving through a shallow creek?  Do you guys think its worth doing the mod of making a new vent hose for it and welding the old vent hole shut?
Re: Wheeling a 4 banger with an auto...
« Reply #1 on: June 06, 2013, 07:49:28 PM »
Length the vent hose and run it up the firewall.  You don't want to weld it shut.  The transmission needs to vent otherwise it will blow seals.
Offline VA_YJ
  • Now I need a CJ...
« Reply #2 on: June 07, 2013, 08:38:52 AM »
I agree with Jeffy, you don't want to plug the vent hole.  I just want to add that you can also put a bellows on the end of the vent line instead of an open breather.  I'm using the PSC vent bellows PSC-VB01 on my TJ build.  The bellows keeps the water out and still allows the air in the tranny to expand and contract so the seals don't pop.  I'm using the vent bellows for axles and transfer also.
http://www.polyperformance.com/shop/PSC-Vent-Bellow-p-17158.html
« Reply #3 on: June 07, 2013, 08:42:34 AM »
That is a great idea!
Offline VA_YJ
« Reply #4 on: June 07, 2013, 08:50:28 AM »
The bellows are a little pricey ($9 each + shipping), but PolyPerformance has sales on a regular basis (10% off and such).  I waited for a sale and bought several at once to get the unit price down.
« Reply #5 on: June 07, 2013, 09:04:47 AM »
would be interesting if you can install those at the same level as the seals so if submerged would compensate for the water pressure, only problem is that it might fill with trans fluid in time.
« Reply #6 on: June 07, 2013, 09:16:45 AM »
Maybe balloons could be used, or plastic bags.
« Reply #7 on: June 07, 2013, 02:17:09 PM »
Just get a T-fitting and tap it into the transfer case breather that goes to the firewall.
Offline VA_YJ
« Reply #8 on: June 07, 2013, 03:03:05 PM »
"Just get a T-fitting and tap it into the transfer case breather that goes to the firewall." - not a bad idea if both the tranny and transfer are using ATF.  Some transfer cases (e.g., atlas) don't use ATF and you would not want any mixing.  This is possible - my rear axle pukes gear oil out of the vent tube sometimes in cold weather.
95yjman
« Reply #9 on: June 07, 2013, 07:19:07 PM »
Its a 30RH...there is no vent hose...Its vents via a hole in the pump housing behind the Torque converter..
« Reply #10 on: June 07, 2013, 07:41:23 PM »
Seems some people have been JB Welding brass fittings to the opening then drilling a hole through the bellhousing.
« Last Edit: June 07, 2013, 07:42:30 PM by Jeffy »
« Reply #11 on: June 07, 2013, 09:01:08 PM »
can it be vented out of the fluid level tube?
