Author Topic: BOSCH II UPGRADE FUEL INJECTOR SET 4-HOLE NOZZLE (4) 96-02 Jeep 2.5  (Read 4105 times)
Offline DOTSON53
Is anyone using these? Would you recommend them? And what too expect. Thanks
Offline SamsonJR
  • Samson Jr and Willydog in VT
Re: BOSCH II UPGRADE FUEL INJECTOR SET 4-HOLE NOZZLE (4) 96-02 Jeep 2.5
« Reply #1 on: July 13, 2013, 10:39:07 PM »
just yesterday I put in a set of yellow top 4 spray ford injectors into my 91, they are 19lb. the Tj's run a higher pressure compared to the yj's I think around 49 psi, I don't remember completely, the yj runs around 31. but same basic principal, a 4 spray injector is superior IMO to a single spray, better atomization of fuel. I noticed a slightly better idle and smoother acceleration. nothing to amazing but every little bit helps. This swap with a 4.0 TB brought back some life I felt like I lost after my lift. hope that helps
« Reply #2 on: July 13, 2013, 10:57:34 PM »
TJs already have 4 nozzle injectors from what i know (or maybe the later models). You'll need something like 24lb/hr at 49 psi to get a bit of performance increase, if you're not after that then no reason to swap, there are a few threads with part numbers that work for TJ from guys that did this successfully, one that i recall needed pigtail adapters for the injector connectors so watch out for that as well.
« Reply #3 on: July 14, 2013, 12:59:37 PM »
You might want to read this thread.  It's done on a YJ but goes over them in general.
http://4bangerjp.com/forums/index.php/topic,3479.0.html
I'd recommend going with Design III's not II's.
« Last Edit: July 14, 2013, 01:00:39 PM by Jeffy »
Offline DOTSON53
« Reply #4 on: July 22, 2013, 01:19:08 PM »
Thank, guys I have two injectors throwing codes.
« Reply #5 on: July 22, 2013, 01:45:06 PM »
stock ones you mean?
Offline mrcabinet
« Reply #6 on: July 25, 2013, 04:00:07 PM »
I don't remember the part number, but I have been running 24 lb. 4 hole Ford V6 injectors for a year now and am very pleased with them. A little smoother and a touch more power and gas mileage. If it's stock injectors you need, I have a set that can be had real cheap.
Offline DOTSON53
« Reply #7 on: July 26, 2013, 01:00:11 PM »
Yeah stock ones were making check engine light come on. Bought some off ebay from a neon I think going to give them a try
« Reply #8 on: July 26, 2013, 06:58:50 PM »
did you check the connectors on them? that causes a CEL for an injector most of the time, doesn't mean they can't be bad - i guess you'll find out if you swap them as it would come up again if the connector is the problem.
