Author Topic: elec fan problems  (Read 6052 times)
robertsiii
elec fan problems
« on: August 16, 2013, 06:15:54 PM »
ok im stumped   fan  wont come on and run  after temp exceeds 180 .I tested toggle switch ,replaced temp sensor ,relay and checked solenoid still no go . I can manually get fan to run so its fine .   any ideas ?
Re: elec fan problems
« Reply #1 on: August 16, 2013, 06:35:08 PM »
What are you running, a homemade or some kit?  What parts are you using?  You mentioned a relay and a solenoid...  Where's your temp sensor in relation to the relay?  On the switch side of fan side?  Pictures?
Taking a guess, I'd say if your switch can turn on the fan through the relay then it's the temp sensor that's bad but I have no idea how you wired it.
robertsiii
« Reply #2 on: August 16, 2013, 07:04:16 PM »
homemade   towncar fan  cole hersey solenoid. bosch relay , basic toggle , cant run fan when wired correctly
robertsiii
« Reply #3 on: August 16, 2013, 07:19:01 PM »
brand new temp sensor installed today. should call at 180 shut off at 165 .
« Reply #4 on: August 16, 2013, 08:04:17 PM »
So did it ever work or are you doing this for the first time?  Seems a bit convoluted.  Why not just run one relay?
Do you get power from the relay leg that goes to the solenoid?  Have a multi-meter to check?  That will tell you if your switch circuit is working.  You should also be able to trigger the solenoid to turn on by itself as well.  If both circuits work then it should work.
robertsiii
« Reply #5 on: August 16, 2013, 08:13:39 PM »
been working for 3 yrs . ive changed parts out over the years , relay  temp sensor . it always worked fine . ill do some more trouble shooting in the am
« Reply #6 on: August 16, 2013, 08:18:00 PM »
what does the solenoid supposed to do in that circuit? (is it to cut off the spike?)
robertsiii
« Reply #7 on: August 16, 2013, 08:42:09 PM »
temp sensor engages relay which engages solenoid to run fan . kept burning up relays so I put solenoid in line .
Lah2420
« Reply #8 on: August 17, 2013, 06:28:57 AM »
At the temp it is supposed to work, test to make sure the temp sensor is actually putting out a ground. According to your schematic, it should apparently ground itself? If so, where is it getting its ground?
« Reply #9 on: August 17, 2013, 07:32:45 AM »
it doesn't really make sense, just use a bigger relay, you don't need a 200Amp solenoid to run an electric fan - I do hope you have a separate 12v wire going to the solenoid from the battery, otherwise it won't save the relay at all (if it is just like the diagram you posted would be worse than without the solenoid).
anyway, if it runs when you jump the temp probe then it's fine, otherwise check to see what's missing.
I think he just has them in series which makes absolutely no sense and adds another load to the circuit (but we'll wait to see if he's got another +12v going straight to the solenoid in which case would be somewhat ok)
« Last Edit: August 17, 2013, 07:42:19 AM by sharpxmen »
robertsiii
« Reply #10 on: August 17, 2013, 10:55:39 AM »
yes the solenoid has power straight from battery .   replaced the spade connector on the temp sensor wire , it was makin and brackin - that was the problem
robertsiii
« Reply #11 on: August 17, 2013, 11:11:51 AM »
[/q
yes the temp sensor is the ground in the circuit , it is installed in the intake manifold
« Reply #12 on: August 17, 2013, 11:14:53 AM »
in all honesty i would just ditch the solenoid and go with a 50 or 60 amp relay (just make sure wiring is sized accordingly) - that solenoid is overkill but yeah, will take a lot more abuse.
intake manifold? ??? what's that got to do with water temp? is it a TBI with heating plate? (can't remember if that's the way they are but possibly)
robertsiii
« Reply #13 on: August 17, 2013, 11:25:57 AM »
heres picture of were I put sensor  it is tbi
« Reply #14 on: August 17, 2013, 01:51:11 PM »
your sensor should be past the thermostat otherwise you're starting the fan when you don't need to (as in the thermostat is still closed but you get your engine at 180F and the fan starts, you're cooling the water in the rad that is not hot yet. Something to consider.
