Author Topic: CEL again - 12 33 27 27 55  (Read 2769 times)
« on: October 20, 2013, 08:35:06 PM »
For some reason I'm getting the CEL.  Checked it and it's 12, 33, 27, 27, 55.  I don't think I've ever seen them out of numerical order and appear twice.  27 is the code for fuel injectors not responding properly to the control signal
« Last Edit: October 21, 2013, 12:48:50 AM by Jeffy »
Re: CEL again - 12 33 27 27 55
« Reply #1 on: October 21, 2013, 07:01:23 AM »
Could they be showing in the sequence they happened.
« Reply #2 on: October 21, 2013, 02:48:32 PM »
That doesn't make sense since 33 will always come up.  The CEL lights up later meaning the 27 code is triggered.  And why does 27 come up twice?
« Reply #3 on: October 21, 2013, 02:50:48 PM »
Maybe a scanner would reveal which two injectors are not responding?
« Reply #4 on: October 21, 2013, 04:17:49 PM »
I don't think it's that smart.  The FSM says 27 refers to a fault in banks 3 and/or 4 or 5 and/or 6.  I spend the day checking my ignition system and gaping plugs.  I probably should try resetting the PCM.  I plan on spraying contact cleaner on the plugs.  It only seems to come on when I'm on the highway and it's intermittent.
« Reply #5 on: October 22, 2013, 11:04:52 AM »
I read in the instructions of the new scanner that the codes appear in order of importance, so the first code should be the most critical to the system (if what I read is correct, anyway!).
« Reply #6 on: October 22, 2013, 12:10:10 PM »
Okay, that makes sense.  Still wondering why it comes up twice.
« Reply #7 on: October 22, 2013, 12:44:54 PM »
could it be last or active code related (as in the others went away but still stored, this was the last/more recent code - I cannot remember since last time i pulled a code if that's the case or not).
