Author Topic: where can i buy speedo gear?  (Read 4027 times)
Erik
« on: April 02, 2006, 06:07:28 PM »
dealership didn't have a speedo gear... where can i get one?
need part# 53001488   i think
lanulos89
« Reply #1 on: April 02, 2006, 06:11:53 PM »
4wd.com  they have them i believe
Jeepguy214
Re: where can i buy speedo gear?
« Reply #2 on: April 02, 2006, 06:36:38 PM »
Quote from: "Erik"
That part # doesn't look right to me... I could be wrong though.  How many teeth speedo do you need?   Here's a chart I've went by
http://www.redrock4x4.com/tech/speedo_chart.php
« Reply #3 on: April 02, 2006, 07:25:45 PM »
Quote from: "Jeepguy214"
He's not looking for a TJ speedometer gear.  A 53001488 would be for a 41T Long shaft speedometer gear.
http://www.4bangerjp.com/forums/viewtopic.php?t=731
Might put something in the Wanted forums for the gear.  41T is the standard 2.5L manual speedometer gear.  It should be red in color.
Erik
« Reply #4 on: April 02, 2006, 08:57:01 PM »
41T is stock?
according to that chart, 4.88 gears, 38" tires, would be a 40 tooth... figured a 41 tooth would be the best guess for 40" tires and 4.88's
was i wrong?
BK2LIFE
« Reply #5 on: April 02, 2006, 09:10:26 PM »
ok well the question was "where do i get one?"
any ideas?
« Reply #6 on: April 02, 2006, 09:55:45 PM »
Well, good thing I caught the error I made in my chart.
You'll want a 36T.
Buy them from the Dealer for $12.
Erik
« Reply #7 on: April 03, 2006, 07:18:17 AM »
Quote
Long shaft part numbers (1987-1990)
- 53001492 - 29 tooth speedo gear
- 53001488 - 41 tooth speedo gear
- J3212729 - 29 tooth speedo gear
- J3212730 - 30 tooth speedo gear
- J3212731 - 31 tooth speedo gear
- J3212733 - 33 tooth speedo gear
- J3212734 - 34 tooth speedo gear
- J3212735 - 35 tooth speedo gear
- J3212739 - 39 tooth speedo gear
- J3212740 - 40 tooth speedo gear
no 36 listed.... 35 i suppose?
« Reply #8 on: April 03, 2006, 02:10:11 PM »
Well, there could be but you'd have to have someone look it up.  Most of that stuff is special order.
I had a friend at the dealer look it up for me.  According to most sites out there, there was no 37T for my '92.  I was going to get a 36 and a 39.  He looked it up and found one.
I'll give you contact info in a PM.
KS98TJ
« Reply #9 on: April 07, 2006, 08:24:33 PM »
I buy all my Mopar parts from www.chryslerpartsdirect.com , a dealer in NJ.  The shipping is cheap and timely; the prices can't be beat.  They even know me by name now...
