Author Topic: Adding Rear Bumper to YJ  (Read 1516 times)
« on: July 05, 2014, 07:39:57 PM »
I've owned this 4bngr YJ for couple years now. I'm starting to collect items and add to them to the YJ. I've picked up this Smittybilt rear bumper for a TJ. The mounting locations are the same for my 94 YJ. I know the rear portion of the YJ's frame tend to rust out from the inside. The rear bumper is not enclosed so I cut holes in the rear crossmember and the bumper mount so that when I wash out the frame, the debri will flow out as well.
Did similar to my TJ years ago when I added the Tomken rear bumper to the TJ. TJs have a 'drain/access' hole in the bottom of the most rear portion of the frame. However, I've added the angle support brackets for the ears of the TJ frame so the drain/access hole is little constricted.
For the YJ, I welded the 'wing support plates' in.
Re: Adding Rear Bumper to YJ
« Reply #1 on: July 06, 2014, 02:19:06 PM »
That's a good idea. I drilled some 1/2" hole in the side bottom of my YJ frame to allow water to drain out.  It is a trouble spot for YJs, no way to drain the rear part of the frame (except through the nut which will allow some water to pool).
« Reply #2 on: July 13, 2014, 07:49:37 PM »
One of these days I'll have a rear bumper...
