Author Topic: Where do I find the special tool to remove safety torx screw  (Read 3312 times)
Beachbum
« on: April 07, 2006, 12:28:34 PM »
Where can I buy the special tool to remove safety torx screws on the AIS port on the throttle body? Is this something an auto store should have or do I need to try and order it somewhere, thanks for any help.
« Reply #1 on: April 07, 2006, 12:40:25 PM »
They're called Tamper-proof Torx.  I bougth my set off eBay for $4.
http://search.ebay.com/tamper-proof-torx_W0QQfromZR41QQsatitleZtamperQ2dproofQ20torx
I believe Sears might have some but I'm not sure if they're Craftsman Brand.  I've seen a set in Radio Shack also.
Or you can try snapping off the center stud and using a regular set.  I have not tried this since I ended up buying the propper tool.
Erik
« Reply #2 on: April 07, 2006, 01:10:04 PM »
advance auto carries them with the rest of their tools in the tool section.... i think their are 6 in the set but i could be wrong.  ampro brand.
littleredbeater
« Reply #3 on: April 07, 2006, 01:33:41 PM »
auto zone too, I broke one within an hour an took them back. I wish I could find a set of stainless ones.
Erik
« Reply #4 on: April 07, 2006, 02:12:16 PM »
harbor freight possibly?
or drop a dime with snap-on.... just buy the size you NEED so you won't be wasting your money on other sizes that will otherwise colelct dust and take up space in your toolbox....
« Reply #5 on: April 07, 2006, 02:12:29 PM »
The torx on the TB have blue locktite on them.  Usually it's all dried and doesn't take much work to remove.  I would not use a ratchet since it's very easy to apply too much force and either screw up the head or snap it off completely.
I'd maybe put each tork under a candle or lighter for a few seconds then remove.  It won't take much heat.
Erik
« Reply #6 on: April 07, 2006, 02:47:11 PM »
blow torches are so much more fun though  :twisted:
