Author Topic: Hard to shift into first  (Read 7055 times)
« on: October 05, 2015, 04:53:48 PM »
Lately, my YJ has gotten harder to shift into first when at a stop and running.  It shifts into all gears smoothly and easily with the engine off at a stop and when in motion with the engine running.   I am thinking this means the throwout bearing or pilot bearing is no longer properly lubricated.   Does this sound about right?
Re: Hard to shift into first
« Reply #1 on: October 05, 2015, 05:26:39 PM »
Sounds normal for an older YJ with worn syncros.  If it was the throw-out bearing you wouldn't be able to shift into any gear without rev matching.  You can shift from send into the neutral position and hold it there for a fraction of a second and then it should shift into first.  You can also shift it into first till it doesn't want to move then let it back and then try again.  It should go in.  First gear from a stop sometimes just need a firm shove.  Keep in mind that there is a 1st gear lockout pin to prevent you from shifting into 1st from 2nd.  There are tricks to get around it though.  I'd also probably recommend changing the fluid but that doesn't always seam to help.  Mine's notchy as they say.
« Reply #2 on: October 06, 2015, 01:19:57 PM »
Thanks.   It's still not so bad that it would be a must fix.  I'll wait and see how it behaves for a while and then decide what to do.
« Reply #3 on: October 21, 2015, 10:38:30 AM »
sounds more like it doesn't disengage properly (clutch), is it better if you pump the clutch pedal a few times? if yes might want to look at the master/slave/fluid for the clutch hydraulics, if not could be a pressure plate issue.
try what Jeff said with shifting in 2nd and then move to 1st, if that works better could be a syncro but 1st is actually not as common with this problem as 2nd and 3rd as far as I know.
« Reply #4 on: October 21, 2015, 11:27:02 AM »
Thanks, I'll try pumping the clutch to see if it has an effect.
« Reply #5 on: October 23, 2015, 09:05:53 AM »
Pumping the clutch does not seem to make a difference.  I also tried putting it in low low and first gear to see if it would move forward with the clutch pedal pressed, but it did not move.  So it seems the clutch is disengaging.  So the  most likely thing is the first gear synchro?
« Reply #6 on: October 23, 2015, 01:27:27 PM »
I guess but if you're standing still with the clutch pressed it shouldn't be an issue (the syncro), many old trucks had no syncro on 1st for that matter as it was only used for getting moving from a standing start and not while rolling.
« Reply #7 on: October 23, 2015, 02:33:36 PM »
That is true. My father used to have a truck like that.
I still think it could be the pilot bearing or throwout bearing keeping the input of the transmission spinning.  It is also almost never possible to get into reverse at a stop without a lot of grinding or shifting into other gears first to try to stop the input.  Even after shifting into second or third, which should stop the input, as soon as I try to shift from those gears to reverse, it is almost always grinding again.   And with the motor off, it shifts into 1st very easily.
« Reply #8 on: October 23, 2015, 03:14:36 PM »
If it's the throw out bearing then you'd have the same issue in all the gears.  1st and Reverse have stops.  Really, you're supposed to shift into 1st them to reverse.  Double clutching should also work.
Easy shifting with the engine off would suggest it's the syncros since they don't come into play.
« Reply #9 on: October 23, 2015, 04:20:55 PM »
How are these stops supposed to work?   Maybe my AX5 is missing something after the rebuild it had some years ago.
« Reply #10 on: October 23, 2015, 05:03:19 PM »
I should clarify that.  Reverse has a lock-out mechanism.  To bypass it you need to shift into neutral.  Meaning the shifter needs to be vertical, between 3rd and 4th.  They used to tell you to shift into 1st to make sure you're not doing something stupid.  1st is notchy and can be finicky too boot.  If it's too cold or too warm, you can lose 1st all together.  It's a problem that plagued the AX-5 and AX-15.  When it's in the low 40's, it can cause really hard shift till the transmission warms up.  I used to always just shift into 2nd when that happened.  I've also ahd really hard shift when it was really hot or at least humid.  It wasn't like when it was cold and I was locked out of 1st completely but it was really difficult to shift.  All the other gears were fine.
Some people have had luck with a fluid change to something synthetic.  I've had mine taken to the dealer and they weren't able to find anything wrong.  I haven't bothered to switch to any other fluid then what the factory put into it.  I think of the AX-5 as an old school transmission that doesn't like being rushed.  1st can still be stiff but I haven't had it lock itself out in a very long time.  If it's stiff, I'm usually automatically double-clutching to get it into gear.  I think it's fault in the design.  There were never any TSB's for the AX-5 or AX-15 for the shifting issues even though they were common place.
« Reply #11 on: October 26, 2015, 09:02:57 AM »
Thanks.  It sounds kind of like what is happening with my AX5 is fairly normal for its age.   I'll just wait and see how it evolves.
« Reply #12 on: October 26, 2015, 01:47:24 PM »
I forgot to mention, mine clunks when i shift into 1st from from a stop sometimes.
« Reply #13 on: October 28, 2015, 01:38:10 AM »
it's the pressure plate most likely, never seen a pilot bearing doing this, I mean if it was seized you wouldn't be able to shift at all.
I don't think the reverse has a syncro
« Reply #14 on: October 28, 2015, 08:52:07 AM »
Thanks.  This will make me more likely to  change the clutch as soon as it gives me any additional reason to do so (it's old, probably about time anyway).
