Author Topic: PT Cruiser Turbo  (Read 2504 times)
Offline DanMarino
PT Cruiser Turbo
« on: April 13, 2016, 09:56:31 AM »
Question for you Jeep experts.  If I remember correctly, Chrysler put a 4 banger turbo in their PT Cruisers.  Does anyone know if that is the same engine as the 4 banger in the TJs?  If so, wouldn't it be possible to swap some parts or engines to boost a TJ?
Thanks,
13
Re: PT Cruiser Turbo
« Reply #1 on: April 13, 2016, 12:31:27 PM »
It is and it isn't.  The bottom end is beafed up and because it's a transverse engine, the exhaust manifold is upside down for what you'd need.  A guy in Reno, Sierra-something (here) had made some adapters but I haven't seen him on here in ages.  He might still be on the Reno4x4 forum btu I'm not sure.  In any case, he was going to do a SRT4 swap then ended up using the exhaust manifold/turbo on the stock bottom end since it was too much a PITA to swap it all over.  Try searching for his threads here.
« Last Edit: April 13, 2016, 01:42:19 PM by Jeffy »
Offline DanMarino
« Reply #2 on: April 15, 2016, 06:14:14 AM »
I'm guessing that my 2.5 liter AMC motor is different than the 2.4 liter Dodge/Chrysler motor.  Sounds like the turbo 2.4 used in the PT Cruiser and sporty Neon had a more robust bottom end with forged rods and different pistons.  This seems like a pretty neat modification if someone made it work right.  Seems like the engine bay would have plenty of room once an electric fan was installed.
« Reply #3 on: April 15, 2016, 01:03:08 PM »
It's a completely different engine then the 2.5L.  2002-2006 TJ's used the 2.4L which is the same engine.
- http://www.reno4x4.com/showthread.php/5362-Turbocharged-2-4L-Jeep-TJ-for-me!!!
For the amount of work it would take to swap a 2.4L in place of your 2.5L, you could install a turbo on your 2.5L.  Or swap in a 4.3L or even a 350/5.7L.
« Last Edit: April 15, 2016, 01:03:53 PM by Jeffy »
Offline DanMarino
« Reply #4 on: April 19, 2016, 07:03:56 AM »
I thought one of the advantages of the PT Cruiser 2.4 turbo is the forged internals / different pistons?
Anyway, won't the 2.5 blow up if a turbo is added?
Is there a turbo kit available for the 2.5?
« Reply #5 on: April 19, 2016, 06:47:50 PM »
[/quote[How much boost are you planning on?  You can safely run 5-8lbs of boost on a N/A block.
