Author Topic: double cardan shaft in an offset diff.  (Read 2160 times)
6099
« on: April 21, 2006, 02:52:56 AM »
Is this possible or does a double cardan shaft have to operate in a straight line to be vibe free?
I know you can run a conventional driveshaft in an offset diff.
ratherbejeeping
« Reply #1 on: April 21, 2006, 09:30:43 AM »
the shaft doesn't know the difference between up and down angle and side to side angle....
so what exactly are you asking here?
6099
« Reply #2 on: April 24, 2006, 01:10:58 AM »
"the shaft doesn't know the difference between up and down angle and side to side angle.... "
So you're saying a double cardan drive shaft behaves the same way? That it doesn't know if it's operating up/down/side/side angle?
« Reply #3 on: April 24, 2006, 11:09:20 AM »
Sidew to side, up and down it's all the same angle to the U-joint.
