Author Topic: Brake Problems  (Read 2400 times)
huit-huit
Brake Problems
« on: April 23, 2006, 07:54:17 PM »
Background: 93 YJ
I did an axle swap a dana 44 and a dana 300 Transfer case..
Everythign is done we bleed the breaks and got presure . As soon as we started the jeep and the pedal went to the floor. We thought it might be the master cylinder . So i replaced it same problem.. I need help
Brake Problems
« Reply #1 on: April 23, 2006, 08:06:28 PM »
What's the D44 from?  Have any idea what size the brakes are?  Are you just bleeding the rears?  Are you running the booster?  Checked for leaks, I'm sure.
huit-huit
Brake Problems
« Reply #2 on: April 23, 2006, 08:46:02 PM »
Ya im running a boster. Cherokke Front.. Im bleeding them all
Brake Problems
« Reply #3 on: April 23, 2006, 09:00:09 PM »
If the brakes are adjusted correctly then I'd guess that the MC might not be making enough pressure for the rear brakes.  I'll take a guess and say the rear's are at least 11" drums?
wrangler387
Brake Problems
« Reply #4 on: April 23, 2006, 09:49:01 PM »
You sure you dont have a leak and that you got all of the air out of the lines? a leak or air in the lines would cause these symptoms. or MC is to small.
SMC4WD
Brake Problems
« Reply #5 on: April 23, 2006, 10:18:48 PM »
I've heard of this one before on another post...  It's one of those "my computer doesn't turn on...  did you check the plug?"
Well make sure that the right side caliper in on the right side, and the left is on the left.  It sounds stupid, but the bleeders are specific, and make sure air isn't sitting in a pocket.
I have a 95 YJ with a D30 & F9" rear...  I haven't had good brakes in years...  It's almost scary at times.  I've bled them too...  I had brakes, life was good then I took a rear caliper off, compressed the brakes (by accident) and haven't had a good pedal feel ever since.
I wish you luck, and I hope that someone here can help!
