Author Topic: Clutch Bleeding ?  (Read 4507 times)
JWJeeper94
Clutch Bleeding ?
« on: May 10, 2006, 06:23:31 AM »
I have a 94 Wrangler, 2.5 I have been learning about alot of things and doing moderately well, even changing the chocolate milk that came out of the tranny when changing the fluid, got jeep from auction. I have tried numerous times to understand where the bleeder is for the tranny.What it shows in the book and what I'm looking at seems to be two different things.they show a bleeder screw,and the line going in seperately. All I see is a black tube ( slave )with the line running into it. checked both sides of tranny and there seems to be no seperate bleeder. Now this slave seems to be bolted on with the two dust cap screws. but the line also seems to be immoveable.there is a zip tie around the line over the slave nipple.for the love of mankind please help me figure this out.Allthough this seems like a simple task it is just frustrating.I am under the immpression that it needs bled. When stopped and try to put into gear it won't go,unless you match rev the engine 2-3 times and find the right RPM's
shotgun
Clutch Bleeding ?
« Reply #1 on: May 10, 2006, 08:17:07 AM »
Some Late 94's and 95's have an external slave. This sounds to be what you are describing. Not all external slaves are bleedable. I have a TJ friend who bought a replacement and  he had to bleed it before installation as the slave did not have a bleeder valve. Qtec used to have a pdf describing how to do this, my searching isn't proving very successful.
JWJeeper94
Clutch Bleeding ?
« Reply #2 on: May 10, 2006, 09:46:25 AM »
I appreciate the help and now at least I know what it's called. The book I have (haynes) has served me well on alot of the things I have done. However it doesn't show anything on the slave cylinder except to bleed it.Do you know what's involved if I remove the slave cylinder ? can I bleed it that way or are springs going to fly, fluid loss, and can it be put back in easily?
JWJeeper94
Clutch Bleeding ?
« Reply #3 on: May 10, 2006, 12:30:51 PM »
anyone know ?
how to bleed an external slave ?
Clutch Bleeding ?
« Reply #4 on: May 10, 2006, 01:13:09 PM »
Does it have a hex worm in the side of the slave?
JWJeeper94
Clutch Bleeding ?
« Reply #5 on: May 10, 2006, 07:31:56 PM »
yes it does , what I have tried was what the manual said ,,, depress the clutch and open screw , when nothing came out I assumed that wasn't the bleeder.  Please tell me it is and you can enlighten me as to how it is done. The closest thing I can find that looks almost the same is an Omix-ada slave cylinder, couldn't find any info or diagrams on it.
Clutch Bleeding ?
« Reply #6 on: May 10, 2006, 07:45:45 PM »
I think it is the bleeder.  Pump up the clutch till it's firm then open the bleeder then close with the pedal still to the floor.  Keep trying till, all the air is out.  Might require several attemps.  Are you atleast getting air to come out?
I've never delt with the non-zerk bleeders though.  Can't pump fluid up the line like you can with the zerks.
JWJeeper94
Clutch Bleeding ?
« Reply #7 on: May 11, 2006, 07:17:03 AM »
Well now my leg is ready to fall off, Jeffy I pumped that clutch endlessly even thought if I started the engine (don't ask) it would make a difference. It didn't, pedal goes down with little effort and doesn't "pump up" I have bled brakes in my day so I suppose I'm looking for that stiffness in the pedal, which I didn't find. If we figure this one out we should get a medal.I think I'm going to stop at the aamco and see what they say. If they can bleed it it'll be worth the money to save my sanity, I'll let you know what happens so you can pass it on.
littleredbeater
Clutch Bleeding ?
« Reply #8 on: May 11, 2006, 07:37:37 AM »
stupid I know but I've done it........ don't forget to fill your resivoure with fluid after every two or three bleed attempts.
(Pedal to floor-open bleeder- close bleeder- let pedal back up) Repeat twice then refill fluid.
This is what I've had the best luck with. I just did my clutch too. Good luck.
JWJeeper94
Clutch Bleeding ?
« Reply #9 on: May 11, 2006, 03:56:32 PM »
thanks for the reminder, although when I open the bleeder ( I assume that's what it is) nothing comes out. And the guy's at aamco weren't even sure if an external cylinder could be bled, but they offered a $39.95 external diagnostic, which we know where that would end up ( in my wallet for anything related to the part in question) so I declined their generous offer.The quest continues!!!
Clutch Bleeding ?
« Reply #10 on: May 11, 2006, 05:32:57 PM »
Let me ask my friend about it.  He's a Service Manager.
shotgun
Clutch Bleeding ?
« Reply #11 on: May 12, 2006, 07:39:11 AM »
the qtec link is supposed to be www.quadratec.com/pdf/slave_cylinder.pdf
Some after market slave's have a screw that looks like a bleeder, but is not.
Try  this.  Take the slave off and  cycle it in a "bowl" of DOT5 fluid till all the air bubbles disappear. Another theory is these slave's are self bleeding.(yeah right) Attache the slave to the line but not to the bell housing. cycle the piston by hand ensuring the fluis level stays up.
Clutch Bleeding ?
« Reply #12 on: May 12, 2006, 12:07:45 PM »
Well my friend said that if it came with the tube, it's been preblead.  If not then you're supposed to be able to bleed it through the allen.
JWJeeper94
Clutch Bleeding ?
« Reply #13 on: May 16, 2006, 06:52:05 AM »
I talked to some people that wrench on a variety of auto's and the general consensus is to pull the slave out and see is the rod is adjustable, gonna try this when the weather is a little less wet here.I'm considerinf replacing the whole system, master and slave to just circumvent this problem, what do you think? and any prefered type ?
I appreciate everyone hanging with meto this point on this and going out of their way to find answers , thank you
stanton
Clutch Bleeding ?
« Reply #14 on: May 16, 2006, 01:48:54 PM »
Hi mick here from across the pond,check that there is a hole drilled
below the grub screw.Ive changed two so far,( tj andxj) and both
had the grub screw  but no bleed hole drilled under the screw.
  Micky S
