Author Topic: installed half my lift  (Read 3078 times)
lanulos89
« on: June 03, 2006, 10:52:31 PM »
well today i installed half my lift.  The back half and the t case drop. Its a 3.5",  all went smooth, except when i now goto shift its hard to shift it. Its a automatic tranny so my guess is i gotta ajust some tranny linkage or something any ideas, i will post some pics morow when it is complete.
yjdave
« Reply #1 on: June 04, 2006, 10:25:41 AM »
I have a 3.5 as well, but with a manual, and yes i had to trim a bit the plastic around the gear stick (excuse my english). "nd and 4thg would eventually skip out on bumpy roads
lanulos89
« Reply #2 on: June 04, 2006, 06:09:53 PM »
well its done here some pics
Before
After
« Reply #3 on: June 04, 2006, 07:18:00 PM »
Looks like you need to trim the U-bolts down a bit.  Throw on some 33x9.5R15's and you'd be set.
j-freak153
« Reply #4 on: June 04, 2006, 07:58:56 PM »
33x10.5r15....thats what i have and they are awesome...BFG AT come's in 9.5", MT are 10.5"....they make 10.5" boggers in 35".....those would be BAAAAD 8)
SMC4WD
« Reply #5 on: June 04, 2006, 08:22:09 PM »
It does look really good.  The Jeep is coming to look very 4wd worthy.
Jeffy mentioned Ubolt Skid plates.
HEAVY DUTY SPRING PLATES FOR 2 1/2" WIDE SPRINGS W/SHOCK OR SWAY BAR MOUNT
Mfg:  Currie Jeep
Our Price: $104.95
Description: These Spring Plates are built to withstand the most rugged off road abuse. They have a built-on skid plate to protect U-Bolts. The top plate is 5/16" steel and the bottom (skid plate) is stamped out of 1/4" steel. These Heavy Duty Universal Spring Plates are designed to be used with 2 1/2" wide springs and come with optional shock or sway-bar mounts - please specify when ordering. Price listed is for a pair of plates.
Unit of Measure: Pair
These are a great direction to go too!!
« Reply #6 on: June 04, 2006, 10:59:30 PM »
Quote from: "j-freak153"
Did you ever take picures of your Jeep with the 10.5's?
Boggers really suck if you have to drive on road a lot.  They have 34x9.5R15 TSL's and a cheaper 34x10.5R15 LTB also.  For a daily, you'd be better off with a radial tire.  I know Dunlop or someone also makde a 33x10.5R15, too.
Quote from: "SMC4WD"
I mentioned trimming his bolts.  Those Currie plates are HUGE.  I should know, I run them out back.  They're like pontoons. :lol:
If I was going to replace my spring plates I'd go with something like the JKS plates.
