Author Topic: no dash ligths at night!  (Read 1989 times)
bigbrad_4x4
« on: June 23, 2006, 03:05:07 PM »
I don't know if this problem has already been posted, but I've looked and couldn't find the same issue.
Lastnight after I went fishin, I turned on my lights, and none of my interior lights came on.  The only lights were from the odometer, the high-beam, and the radio, I couldn't see my speedo nor any of my other guages.  My taillights also don't come on.  All that comes on are the headlights.
Any one have any ideas?  I need this issue fixed ASAP!
Thanks.
GreenBayjeeper
« Reply #1 on: June 23, 2006, 06:14:38 PM »
I'm sure you checked, but it needs to be asked.
Did you check your fuse panel?
« Reply #2 on: June 23, 2006, 06:42:00 PM »
Check fuses then check connectors, bulbs and switches.  You might also want to mention what kind of Jeep it is.
bigbrad_4x4
« Reply #3 on: June 24, 2006, 12:39:31 AM »
I checked every fuse on it.  I haven't checked any switches or connectors yet.
It's a 2003 TJ SE.
« Reply #4 on: June 24, 2006, 06:27:01 PM »
on my 90 yj i have no dash lights and only 1 headlight that works.. itrs an electrical nightmar.. and its very nervraking driving at night...
zeitlerusmc
another dumb question that has to be asked
« Reply #5 on: June 29, 2006, 11:21:40 AM »
did you make sure you didnt turn down the dimmer switch on your turn signal lever the same one that controls your dome lights
  • Poseur ExtraordinaireŽ
« Reply #6 on: June 30, 2006, 07:28:35 AM »
If the dash AND tail lights aren't working it sounds like it is definitely a bad fuse.
« Reply #7 on: June 30, 2006, 12:05:52 PM »
Head light switches are known to go bad also though.  Check the fuses under the hood.
bigbrad_4x4
Re: another dumb question that has to be asked
« Reply #8 on: June 30, 2006, 09:30:35 PM »
Quote from: "zeitlerusmc"
I'm pretty sure cause I never dink with it, plus that wouldn't explain my tail lights bein out.
But I rechecked EVERY fuse on my Jeep, and looks like I overlooked a couple blown fuses  :lol:.  I replaced them and everything works they way they should now.
Thanks for the help.
