Author Topic: Scout II axles  (Read 1954 times)
larhan
Scout II axles
« on: June 26, 2006, 07:28:48 PM »
I was wondering if anyone knew whether 44's from 80 Scout II would fit my 94YJ.  thanks
Scout II axles
« Reply #1 on: June 26, 2006, 08:50:34 PM »
The rear will work BUT you'll have to get the rears redrilled for 5 on 4.5" rather then 5 on 5.5".  Width wise, it's fine.
The front won't work unless you have a passenger side drop transfer case.
Scout II axles
« Reply #2 on: July 08, 2006, 11:57:39 PM »
Not to mention the Scout front 44 is a poor choice due to 0º caster, you'd have to have the knuckles cut, rotated, and welded to have proper handling.
Take a look at a Waggy front and rear D44 from late '80s or '90s, or a Waggy front D44 and an Isuzu rear D44, this will give you matching 6-lug axles and 4whl disc brakes.
