Author Topic: T case drop  (Read 2841 times)
Liljeepz
T case drop
« on: July 07, 2006, 08:12:13 PM »
A guy from the local club gave me a T-case drop kit, Looks like 6 bolts and 6 spacers.
What is the best way to put this in?
any tips?
Not sure what all is invalved, I plan on riping into it tomarow morning first thing.
Thanks in advance.
Re: T case drop
« Reply #1 on: July 07, 2006, 08:35:26 PM »
Quote from: "Lilzen"
any tips?
Thanks in advance.
Place a floor jack under the skid.  Use blocks of wood to make the difference.  Loosen the bolts then lower the skid 1.5".  Then drop in the spacer and raise then tighten.  Not much really to it.  I removed mine though.  I like having the shifters up higher again.
Liljeepz
T case drop
« Reply #2 on: July 07, 2006, 08:48:33 PM »
I just found This Just the T case part tho, not the lift.
It looks like the same kit...
when the skid plate drops the T case drops too? are they attatched? Do I need to losen any thing elce?
This is just a temp fix tell my MML/BL comes in, 2-4 weeks.
I hope i get it intime to be at camp jeep with them!
T case drop
« Reply #3 on: July 07, 2006, 08:55:06 PM »
the scid plate is the suport for the tcase.. so they drop together.. just undo the 6 bolts and put in the spacers and new bolts.. ow ya i dont know how old your jeep is jbut you might want to spray some wd40 or penatrating fluid ion the bolts to loosen them.. i needed it when i did it on my jeep....
1 question thow.. why are you puting it on .. did you get a lift were you need the drivshaft anger to be better cuz if you dont need it i wouldnt tell you need it.. cuz i personaly think they look cheap and not so good and also you loose grund clearence..
Liljeepz
T case drop
« Reply #4 on: July 07, 2006, 09:08:23 PM »
Ya I put in ACOS in last weekend, I set then about 2-2.5" and gave me bad vibrations.
here is a link for the thread earlyer this week I started, but this is a diffrent topic so i started this one.
Liljeepz
T case drop
« Reply #5 on: July 08, 2006, 12:35:13 PM »
In and done! Very simple!
Only problem was the bolts where not right. they where standered and my jeep uses metric.
So i ran to ace hardware and got some new bolts. altho they didnt have enough so I mixed diffrant lengthes and put in spacers to make it work.
I just need it to get me to work and back tell my parts come in then its coming off.
Only problem is now that when I have it in 2nd and 4th gear the shifter poll hits the plastic housing now, Dose any one know if there is a way to move it? Im sure once the MML/BL is in I will have the same problem.
T case drop
« Reply #6 on: July 08, 2006, 01:39:20 PM »
in the instructionns that came with mine it said you may have to cut that if it hits.. but mine didnt hit so i didnt need to cut anything...
Oilsmoke
T case drop
« Reply #7 on: July 09, 2006, 10:01:32 AM »
Lilzen Are you Using a SYE?
If not you Should there are Lot of Benfits to it.
Liljeepz
T case drop
« Reply #8 on: July 09, 2006, 11:12:41 AM »
I will some day, but I have a lot of other things I need more. I will get one once I get a larger lift. I'm shure that is a few years down the road.
  • Poseur ExtraordinaireŽ
T case drop
« Reply #9 on: July 09, 2006, 08:46:47 PM »
Hah...installed my lift today (see thread in Poseur Central) and forgot about the shifting issues I would have...4th is my biggest problem, but 2nd and reverse aren't so hot either.
Just planning on pulling off the boot next weekend and seeing where I'm hitting.....I could live with it for a few months until I get an SYE.
