Author Topic: gas vacum thing  (Read 5143 times)
gas vacum thing
« on: August 11, 2006, 03:51:03 PM »
ok today i was scrounging around the back of my jeep looking at the lines comeing out of the gas tank becasue when the gas tank is full. it is hard to start (truns over for like 1 minute or more befor starting then when fires exost smell rich like it is fluded) and it leaks gas... and what i found is behind the pasender rear fender there are 2 hoses that should connect and make a loop back to somewere neer the tank (perhapes a return of some sorts).. but the 2 lines go into this 1 inch diameter ruber thing that has a spring in it and tapers back down to the size of the hose that goes back to the tank (im asuming).. so what im asking is what this thing is so that i can get a new one. it broke right at the end of it just above the hose clamp.
 ow ya and its about 3 inches long give or take.
its on a 1990 yj 4banger.. any help apreciated. and vacum or gas line diagrams are welcome.(for this and other issues)
gas vacum thing
« Reply #1 on: August 12, 2006, 11:43:56 AM »
i still dont know what this thing is.. it might be part of a vent thing.. i will be going out to investigate it again in afew minutes and hopefully that helps..
gas vacum thing
« Reply #2 on: August 12, 2006, 02:05:14 PM »
Sounds like you're going to need a FSM or even a Hayes or Chiltons.
Although it sounds weird that anything runs down the passenger side.  All your lines should run down the driver side.  This is because the exhaust runs down the passenger side.  The only thing I can think of is a vent return line from the Evap canister.
gas vacum thing
« Reply #3 on: August 12, 2006, 04:28:02 PM »
well i crawled under my jeep today and ya your right it is a vacume line coming from the vacume canister thing that comes into the top of the spring valve thing and its soposed to conect to a bigger hose that goes into a T and both the hoses off of that goes into the gas tank....
i need to find out what that thing is called or a part number so i can get a new one...
ow ya and i fund that my oil leak was from the oil pan cuz the bolts on it were all lose.. wierd  :nothing: .. dont know how that happend... hopefully that was the only place the oil was comeing from...
and hopefully someone comes along with the name of that weird vacume line spring valve thing... :bow:
ill try to get to the library sometime to see if they have 1 of those bookes i can look at to figue it out if all else fails.
gas vacum thing
« Reply #4 on: August 12, 2006, 07:00:19 PM »
I think your best bet is to upload pictures, I don't have a clue what you're talking about. :nothing:  :english:
gas vacum thing
« Reply #5 on: August 12, 2006, 07:01:46 PM »
thats what i was thinking.. will have to borrow my dads digital camera then.. this could be a day or 2 then...
j-freak153
gas vacum thing
« Reply #6 on: August 13, 2006, 09:03:49 PM »
mines broken off too...when i took and flush mounted my tail-lights, it was half off, the rubber was rotten, and when i moved it, off it came...i havent had time to get it fixed yet but mine seems to be running fine without it being hooked up...
gas vacum thing
« Reply #7 on: August 14, 2006, 07:04:37 PM »
hmm interesting... i cuz my jeep runs ruff whith full tnak of gas and i thought this was the proablem... but if you dont have any poblems...... ill try to get those pics soon.
jeepers
Re: gas vacum thing
« Reply #8 on: August 15, 2006, 09:26:28 AM »
Quote from: "chardrc"
Gas can leak on to the exhaust pipe so fix as soon as you can, or there will be a fire
Its a dealer part. The "Schucks"  or "NAPA" wont have it.
You'll need part:  j536 0058    VALVE,vent
and part:    5300 4047   CONNECTOR
Its best to get both parts and do the job once. If you have the part, take it with you, if not just go to dealer parts and ask for these part numbers. Be sure to tell him, what year and model these parts are for.
Will try to upload photo later. The parts man should be able to give you a printout of the parts brake down he has.
gas vacum thing
« Reply #9 on: August 15, 2006, 05:03:26 PM »
sweet i knew someone had to know about this and have a parts #.. ill have to go down to park jeep then and get the part there.... hopefully they can give us a deal since weve bought a new jeep there the past 2 years.. it got us 2 free tickets to the auto show this year which was sweet... but they proably wount give any parts discounts but it shouldnt cost mugh anyways...
Liljeepz
gas vacum thing
« Reply #10 on: August 15, 2006, 06:16:32 PM »
Quote
 :roflol:
jeepers
gas vacum thing
« Reply #11 on: August 15, 2006, 09:50:53 PM »
Quote from: "Liljeepz"
Quote
 :roflol:
Don't remember what it will cost, but I didn't even have to put pen to paper, when I saw the fuel driping on the exhaust pipe, to know that the part was cheaper repair than a burt up jeep.    :)
gas vacum thing
« Reply #12 on: August 16, 2006, 12:53:07 PM »
true.. ive been lucky that its hasnt blown up yet.... reminds me of when we went to colorado and on a sign it said "warning fire danger extremely high".... adns like 10 miles up the road there was a land rover one fier and you could see the fire working its way back to the gas tank.. adn you could feel the heat in our truck... im like you should have goten a jeep instead of a landrover which is made by ford...
anyway ill go to parkjeep this weekend and get that part or atleast order it cuz they proably wont have one on hand...
gas vacum thing
« Reply #13 on: August 20, 2006, 03:34:05 PM »
thanks for the part #'s they were both good to the surprise of the person workling there.. and i got both on order and they will be here on tuesday...
adn they are going to cost me a total of $26..... not horible but not cheap ether... but hey i wont have to wory about starting on fire.
gas vacum thing
« Reply #14 on: August 20, 2006, 04:36:15 PM »
That's shockingly cheap coming from a stealership.
