Author Topic: seized up grease points  (Read 2430 times)
Jeep4banger97
« on: August 13, 2006, 05:20:49 PM »
I have grease points on my lower control arms, and they arent taking grease, can i replace just the points or do i have to replace the whole lower portion?
Guardian7
« Reply #1 on: August 13, 2006, 06:23:13 PM »
Try replacing the grease fittings first, they should screw out with a small socket or wrench.
« Reply #2 on: August 13, 2006, 06:27:27 PM »
On the fitting see if you can take center punch and tap lightly with a hammer to free up the ball in the center. A lot of times it will just be stuck closed.
« Reply #3 on: August 13, 2006, 07:21:00 PM »
Or else get a needle tip.  The grease fittings official name are Zerk Fittings.  You can pick up a new one for cheap also.
Jeep4banger97
« Reply #4 on: August 13, 2006, 09:57:36 PM »
thanks alot guys, it was starting to squeak a little i dont want it to get any worse! thanks ill try what you said and get back to u!
Jeep4banger97
« Reply #5 on: August 15, 2006, 02:28:38 PM »
yea i ended up replacing the little buggers, yea they were seized completely thanks for your help guys!
