Author Topic: Jeep Articulation!  (Read 7905 times)
Guardian7
Jeep Articulation!
« on: August 17, 2006, 10:21:14 PM »
What dont they do!
SMC4WD
Jeep Articulation!
« Reply #1 on: August 17, 2006, 10:31:49 PM »
:eek:
Now that's twisty!!
My buddy Bryan has a 4 coil renegade....  Look, that this twists too!
Jeep Articulation!
« Reply #2 on: August 17, 2006, 10:42:58 PM »
And with leafs too!
Nice Renegade but loses points for bring coiled.
Guardian7
Jeep Articulation!
« Reply #3 on: August 17, 2006, 11:04:14 PM »
Damn, that's a YJ too, Flex is the Holy Grail I seek!
Jeep Articulation!
« Reply #4 on: August 17, 2006, 11:24:07 PM »
Quote from: "Guardian7"
Eh, it's not that big of a deal.  You don't need to be able to bend over backwards.  The Jeepster looks huge but you have to take into account that it has tube fenders which makes the openings look huge to begin with.
I can't tell with the YJ, if it had a custom coil conversion or a coil-over.
Guardian7
Jeep Articulation!
« Reply #5 on: August 17, 2006, 11:28:24 PM »
Tube fenders are now on my list of things to add, I also like how they are tied into the front bars. It looks like the front shocks are even mounted to the tube fenders, hard to tell how bottom of the shock mounts, it also looks like a shackle conversion on there too!
Jeep Articulation!
« Reply #6 on: August 17, 2006, 11:35:48 PM »
Tube fenders are now on my list of things to add, I also like how they are tied into the front bars. It looks like the front shocks are mounted to the tube fenders!
I really like tube fenders but they aren't legal in many states.  The other problem is most don't have inner fenders.  I like inner fenders to hang my crag on.
Guardian7
Jeep Articulation!
« Reply #7 on: August 17, 2006, 11:38:21 PM »
Do you know if they legal in California?
Jeep Articulation!
« Reply #8 on: August 18, 2006, 07:28:38 AM »
That Renegade also has a different front axle, look at the Warn lockout. It probably has a Ford front and rear axles. Can't see much of a hub or another lockout in the rear wheel. So, that Renegade has gone through some driveline changes.
Flex is good, but if you don't have a properly 'geometric' (if there was such a word) vehicle, what good is flex? If that Commando had the articulation, but was on 29" tires that were on a 3' track width and it still had the 103" stock wheelbase, then what good is the flex. He'll be flopping it all over the place.
Flex is part of the design and layout of the vehicle. Some owners enhance the flex to be capable of driving on their trails. In some instances, it good to have, others not so good. It's a compromise on how much. Leafs can be designed to flex well, but then it's also in where on the frame they attach. The shock is the most limiting aspect of the suspension which limits flex. Most stock shocks only travel 4-5", if that. Aftermarket boosts an additional 1-3" for a 3-4" lift. But if you research properly, measure and locate a shock properly, then your suspension could be designed and laid out to work with the frame, tires, track width, weight capacity, etc of your vehicle. Most owners, I'm one, use the aftermarket to come up with those constraints and work out a suspension lift. It's not rocket science, but there are a lot of factors to consider, quite a bit vary in their numbers.
Jeep Articulation!
« Reply #9 on: August 18, 2006, 12:38:53 PM »
Yes and no.  You will need to make sure the rear tires are covered.  Technically they could ticket you for the front but usually if the rear are covered it's ok.  Many guys who get caught with no tire coverage have to run mudflaps.
SMC4WD
Jeep Articulation!
« Reply #10 on: August 18, 2006, 12:45:26 PM »
OK...  Byrans' Renegade...
Warn 4 coil conversion (before it was purchased by Superlift).  1" Daystar spacer bodylift.
Currie 9" high pinion, Atlas II T/C, 2001 TJ Tranny to a crappy over built 4.0L with chip and intake and all that other perfomance upgrades.
4.56's at each end with ARB's...  Front is a D30 with the Warn 'big bolt pattern' hub conversion.  I joke with him today that my front end is beefier than his because his is still 27 spline and I'm 30 spline.  We both did that custom chromoly over the top steering.
If we were in a parking lot and turned the wheel to the right (or was it left), then punch it!  We used to get the tire to lift and stay lifted few a really long time...  Staying in it, it would run and easy 10 feet plus...
Bryan wanted to take it to PIR (Pacific International Raceways) and race it against some rice rockets...  He wanted to get all four tires smoking with an Advenger supercharger...  He never got around to it because he kept breaking rear ends...  The Currie wasn't strong enough for him.
SMC4WD
Jeep Articulation!
« Reply #11 on: August 18, 2006, 12:46:49 PM »
As I look at these pictures, I noticed that this was before we did our custom high steer thingy...
Jeep Articulation!
« Reply #12 on: August 18, 2006, 01:05:28 PM »
That's one way to get a view of the underbody, nice rig!
Jeep Articulation!
« Reply #13 on: August 18, 2006, 02:36:21 PM »
You don't see too many Renegades with full fenders wheeling very often.
What's up with the 37" tires and a 33" spare?
SMC4WD
Jeep Articulation!
« Reply #14 on: August 18, 2006, 03:02:54 PM »
Sadly, 35's with a 33" spare...  That was also before (my favorite) Wilderness swing away tire carrier.
He sold me those tires and bought 5 more of something...  I can't remember if he went to 36 SSR's...  I guess I'll have to call him sometime.
He wanted to sell me that Wilderness tire carrier for like $200-250.00, but I didn't have the money.   It's probably still on it...
