Author Topic: Sudden engine problem, no clue what it is....  (Read 3618 times)
OrangePeel
« on: September 08, 2006, 01:11:26 PM »
I will give the full list of what I have done if need be however I figured I would wait until asked to keep this as short and easy to read as possible.
Alright here is the down and dirty....
She was driving good, took a little while to warm up but after that would drive fine. Last night though I dropped off a couple of kids at the Church and after that is when things went down hill FAST!!!!
The first thing that happened was that is starrted sputtering and jerking like it was missing. Then it started to backfire and jerk more. I thought it was missing so I drove real slow to get it home but as I went it seemed to get worse. One of the things it would do is when I would give it gas the RPM's would go up then right when it sounded like it would miss they would drop to zero then just before it would try and die it would bounce back up again.
When I got it home the first thing I did was I went ahead and changed the plugs and check the ditributer and points. Those are all good. Next I was thinking that I wasn't getting enough/ or to much air. So I pulled out the K&N air filter that I am using and started it up without it. It seemed to run alright but it would still die on me, just a little bit of a smoother dieing.
My question is this: Could my throttlebody be causeing this? Could it be stuck open or not opening enough to cause this? If so is there a rebuild kit or should I just price out for a new one???
Thanks a million for all of your help
OrangePeel
James (Matt) Holland
« Reply #1 on: September 08, 2006, 01:21:10 PM »
How about starting off by checking the CEL?  If somethings causing the is to run really rought and or die, it should be stored as a CEL.
OrangePeel
« Reply #2 on: September 08, 2006, 01:25:56 PM »
I am going to reset the computer tonight and see if I can pull some new codes. I will list them later. :) Actually I could use some help on knowing what all my error codes mean and what needs to be fixed, but I will post that to another thread on this one I just want to get this imediate problem fixed.
« Reply #3 on: September 08, 2006, 01:54:57 PM »
Just post the codes in this thread since this is your thread on the same subject.
Offline dexetr30
  • 4BangerJP.com® Donator
  • Aloha Mr. Hand!
Re: Sudden engine problem, no clue what it is....
« Reply #4 on: September 08, 2006, 03:31:21 PM »
Quote from: "OrangePeel"
:wink:
I'm a bit confused.... You have a distributor with points on a vehicle that you're able to pull codes from? I had the same symptoms happen to me last week on my boat. Turns out the electronic fuel pump was bad. If you’re running Dodge / Chrysler / Jeep / Plymouth OBD-II, here is a list of the trouble codes:
http://www.obd-codes.com/trouble_codes/dodge/index.php
Good luck.  :thumbsup:
« Reply #5 on: September 08, 2006, 03:36:56 PM »
Quote from: "dexetr30"
:wink:
More like the electronic pickup.
Those codes won't work since they're P codes.  He's got the standard ODBI code scheme.
OrangePeel
« Reply #6 on: September 08, 2006, 05:06:13 PM »
I already have all the codes. :) When I got home before I remembered to pull the codes the first thing I did was pull the throttle body and take a look to see if it is all gummed up from who knows what. Anyway I took some pictures I would like to post so if you all will give me a few I will still go pull the codes and I will also upload the pictures to my photobucket account, then hopefully someone will tell me how to post pics on here as well.
Offline dexetr30
  • Aloha Mr. Hand!
« Reply #7 on: September 08, 2006, 05:26:14 PM »
Sorry I couldn't help with the codes but it's good to hear you have them already.
OrangePeel
« Reply #8 on: September 08, 2006, 06:09:41 PM »
This is the order I pulled the codes. Also 11 is on here twice because it showed up twice when I was pulling the codes.
24 Throttle position sensor over 4.96V
25 Automatic Idle Speed (AIS) motor driver circuit shorted or target idle not reached
11 No ignition reference signal detected during cranking OR timing belt skipped one or more teeth; OR loss of either camshaft or crankshaft position sensor.
65 Power steering switch failure
42 Automatic shutdown relay circuit open or shorted
OR
42 Fuel pump relay control circuit
OR
42 Fuel level unit - no change over miles
OR
42 Z1 voltage missing when autoshutdown circuit energized (The Z1 voltage is the voltage of the circuits fed by the autoshutdown relay. This typically includes fuel pump and switched-battery feed to the ignition coil)
OrangePeel
« Reply #9 on: September 08, 2006, 06:10:41 PM »
Why am I suddenly getting the feeling that I am going to be spending MANY MANY MANY hours reworking my wireing.....
« Reply #10 on: September 08, 2006, 07:27:08 PM »
I'd maybe start off by testing the TPS.
OrangePeel
« Reply #11 on: September 08, 2006, 08:18:28 PM »
Well here is what I got after resetting the computer and then driving around the block to get teh symptoms to happen again and see what codes are thrown at the time and here is what was discovered.
OR
OR
OR
Only one 11 and one 42 this time.
Again thanks for all the help and input.
OrangePeel
« Reply #12 on: September 09, 2006, 07:34:50 AM »
TPS?? What and where is this?
Liljeepz
« Reply #13 on: September 09, 2006, 08:25:40 AM »
Its GOD trying to tell you somthing!!! :shock:
You did say
Quote
hummmm makes you think!  :whistle:
« Reply #14 on: September 09, 2006, 01:30:56 PM »
TPS = Throttle Position Sensor.  Although you said you aren't getting that code anymore.  Maybe check the relay for teh fuel pump.
