Author Topic: Parts question  (Read 1763 times)
Offline dexetr30
  • 4BangerJP.com® Donator
  • Aloha Mr. Hand!
Parts question
« on: September 09, 2006, 02:30:14 PM »
Is the radiator from a 99 Cherokee able to be fitted to my t.j. Is the Cherokee radiator any bigger? Besides the t.b. (which I already have) is there anything on the 4.0.L, Cherokee that my 4 banger Wrangler can benefit from? My scrap yard only has one vehicle at this time that I can swap parts from. I’m just curious about what I can use from it. I figure I may as well go and get as much as possible before it gets crushed.
Re: Parts question
« Reply #1 on: September 09, 2006, 04:07:58 PM »
Quote from: "dexetr30"
The radiator is too big I believe.  Basically all of the accessories will work on the 2.5L.  This includes the water pump, alternator, alternator bracket, AC pump, PS pump, PS bracket, TB, sensors...  If the engine runs, I'd take that as well as the harenss, computer, gauges, transmission and transfer case.  Might as well get the driveshafts too since you can always have those cut down.  Engine mounts will also interchange.
Offline dexetr30
  • Aloha Mr. Hand!
Parts question
« Reply #2 on: September 09, 2006, 05:05:27 PM »
Thanks Jeffy.
yellowta
Parts question
« Reply #3 on: September 10, 2006, 07:57:48 AM »
the cherokee radiator is actually longer and a lot shorter than a wrangler unit. May have the same surface area, but completely different as far as the size and shape.
