Author Topic: Got myself some 19lb injectors.  (Read 14008 times)
Gr8Ride
« Reply #30 on: October 15, 2006, 03:54:43 PM »
I don't know, mine's a TJ though.  Suppose I'd better build a profile.
warro
« Reply #31 on: October 18, 2006, 01:02:06 PM »
I installed the injectors today! I did not change the o-rings. They were in good shape and wanted to try it before putting more $ into them. The exchange went easy. I put some brake/hydralic oil on the o-rings during the install. Used Carb Cleaner to clean the intake. The job took about 45 minutes.
Test run- there is a noticable difference in power above 3k rpm. It is almost like a different power band. I drove up a small hill in 4th and usually bog going up. It did not with the new injectors. I'm going hunting tomorrow and will report on how it performed on bigger hills.
My opionion, I got more power for $28 and am happy so far and was worth doing for me.
warro
« Reply #32 on: October 23, 2006, 10:06:54 AM »
I went up some steeper hills to go hunting and noticed a difference. I don't know about the gas mileage but it is better, I used less getting there driving from spot to spot and back. My wife took the jeep for a ride and agreed that there is better performance. It was worth doing for me and thought it was an easy switch. someday I'll figure the gas mileage
DemonicHuey
« Reply #33 on: October 24, 2006, 06:56:55 AM »
Mustang 5.0 GT Bosch 19 lb/hr Fuel Injectors Design 2 :)
Mustang 5.0 GT Bosch 19 lb/hr Fuel Injectors Design 3  :D
Does this matter if its a Design 2 or 3...????? and can any one post the other threads?
warro
« Reply #34 on: October 24, 2006, 09:41:09 AM »
I used design 3, which come from a newer model ford.
« Reply #35 on: October 24, 2006, 11:46:17 AM »
Quote from: "DemonicHuey"
What's the year cut offs for the different designs?
« Reply #36 on: October 24, 2006, 01:39:51 PM »
I didn't see any on Ebay, but would be willing to split a set of 8 with somebody if they find some.
DemonicHuey
« Reply #37 on: October 24, 2006, 02:44:04 PM »
Quote
These are the Design 3 Injectors and are a nice upgrade for all Design 2 19 Lb/Hr Injectors due to their superior Spray Pattern.  Direct Retrofit for all '86/'93 Mustang 5.0 GT or LX. Ford Injectors
Thats straight off of Ebay.... :nothing: i dont know about superior design
kenny kustom
« Reply #38 on: October 24, 2006, 02:50:15 PM »
what about the larger injectors ? like 34lb ? vrooooommmmmm
kenny kustom
« Reply #39 on: October 24, 2006, 02:58:54 PM »
Quote
 check out that guys feedback... sounds like a bad mamma jamma
« Reply #40 on: October 24, 2006, 05:17:06 PM »
Quote from: "Bounty Hunter"
Buy a set of 8 and sell off the other 4 for 1/2.
« Reply #41 on: October 24, 2006, 05:21:00 PM »
Quote
Ok, then that means I'm running Design 3.  These are the ones pictures in this thread I believe.
wrangler387
« Reply #42 on: October 24, 2006, 10:25:47 PM »
Something i just thought about as i was thinking out my AFPR... where is the information about our 2.5L injectors size? what fuel pressure was the test done at, because i know the 2.5L runs a low fuel pressure.
« Reply #43 on: October 24, 2006, 10:36:09 PM »
Quote from: "wrangler387"
These are the stock 4.0L injectors; DENSO XL5E-A2A 19lb-Pintle
I believe the 2.5L was something like 17lbs for the YJ.  I'll have to double check it with the FSM.
warro
« Reply #44 on: October 25, 2006, 09:46:35 AM »
I bought a set of 4 from skymyke@mindspring.com for $28.00 including shipping. he was seeling them on e-bay. I called and asked for 4. gave me a price and sent an invoice through pay pal. The deal went smooth. He sent his phone # and was good to deal with. I went this way because I did not have to wait for an auction to end and got them sooner. he must deal w/ford stuff because he had design 2 and 3. I went with the design 3.
gas mileage, humm, probably would be better if it my lead foot would stay of the pedal because of the fun response with the injector install. lol
 :D
