Author Topic: U-joints  (Read 2779 times)
U-joints
« on: September 17, 2006, 06:23:28 PM »
Ok, my upper rear driveshaft U-joint is stock, and by stock I mean cira 1992.  It's almost always made some rumbling in 5th when not under power but now it's doing it in 4th and maybe 3rd, so I should probably get around to replacing it.  Now this Jeep is a '92, so I think the U-joint is a 1310 or it could be a 1330.  Amyone know which one it is offhand?  I'm thinking it's 1310 and the lower is a 1330.  Who's changed their pre-93?
jeepers
U-joints
« Reply #1 on: September 17, 2006, 10:22:08 PM »
May be more info than you need -
From '87 to '94.5, the rear diff yoke was a Spicer #2-4-6901-1x and
used a 1310 u-joint, 3 7/32" cap-to-cap.
After that they switched to a Spicer #2-4-7631-1 yoke which used a
1330 u-joint, 3 5/8" cap-to-cap.
If you want to adapt an early driveshaft to a newer ('94+) diff,
you can use a Spicer 5-134x combination u-joint which mates a 1310
yoke to a 1330 yoke.  Supposedly this is a late '70's Ford F250
u-joint.
If you have a '94 YJ, you will have to measure the u-joint to be
sure which type you have.  Pre-94 will have 1310, post-94 will
have 1330.
Good Luck    :)
U-joints
« Reply #2 on: September 17, 2006, 10:30:40 PM »
Ok, that's the pinion end but what about the transfer case end?  I'm not swapping driveshafts.  I just need to replace the yoke before it gets any worse.  I should probably just look it up
jeepers
U-joints
« Reply #3 on: September 17, 2006, 10:34:08 PM »
Both ends should have the same size U-joint.
SMC4WD
U-joints
« Reply #4 on: September 18, 2006, 10:05:24 PM »
Are you going to replace the yoke at the axle side?  Look into converting it into U-bolt style... Well worth the investment.
What rear drive are you running?  Have you already done a SYE? Now's the time to upgrade to Tom Woods...
U-joints
« Reply #5 on: September 19, 2006, 01:06:10 AM »
Quote from: "SMC4WD"
I'll probably replace both U-joints in the shaft since I'll have it out.  I don't have a SYE since I'm still debating on what I want to do with the drivetrain.  Amazing as it may be I've always had the slip yoke and stock shaft.  I don't want to upgrade to a SYE when I may be swapping out the whole transfer case.
U-joint straps are on the to do list, too.  Although I don't overtorque my U-joint bolts so they haven't ever been a problem. :wall:
BlackYJ
U-joints
« Reply #6 on: September 20, 2006, 12:16:14 PM »
The t-case joint was always a 1310, they only changed the diff joint to a 1330.  Also the 1330 yoke for a D35 is a chrysler specific yoke now and you have to get it through the dealer ($$$).  The combo joints are okay, but can cause vibrations.
U-joints
« Reply #7 on: September 20, 2006, 12:36:18 PM »
Quote from: "BlackYJ"
Ok, that's what I thought.  So my drive shaft uses two 1310's and isn't the later 1310/1330 used on later models.
