Author Topic: Wiper/Wash/turnsignal broke steering column won't come apart  (Read 2749 times)
jcoiler
« on: October 03, 2006, 07:03:53 PM »
1991 yj no tilt no intermitent.
The rod inside the turn signal wiper arm broke.  So I am trying to get the wiper control switch out of the column so I can fix it.
I followed all of the haynes manual removed steering wheel, turnsignal/hazard parts, column bracing,dash, lock cylinder, and the 4 bolts but the section will not come apart or off the column to get the switch out.
Please help before I just trash the steering column housing.
Thanks Jason
« Reply #1 on: October 03, 2006, 07:12:56 PM »
Go into the FAQ and look for the '94 FSM link.
Offline dexetr30
  • 4BangerJP.comŽ Donator
  • Aloha Mr. Hand!
« Reply #2 on: October 03, 2006, 07:33:49 PM »
Use a B.F.H. Works every time for every repair job.
« Reply #3 on: October 03, 2006, 07:38:15 PM »
Quote from: "dexetr30"
How many extra parts do you end up with though?  :lol1:
jcoiler
« Reply #4 on: October 03, 2006, 09:07:38 PM »
Spent the last hour + but cant find a reference to the fsm in the faq.  Found some that have the fsm.
Guess it is the crow bat and dremel.
« Reply #5 on: October 03, 2006, 09:21:06 PM »
Quote from: "jcoiler"
18th Post in the FAQ.
http://www.4bangerjp.com/forums/viewtopic.php?t=414
jcoiler
« Reply #6 on: October 03, 2006, 09:33:06 PM »
Quote from: "Jeffy"
Thanks I was searching for FSM DUUUUH
jcoiler
Re: Wiper/Wash/turnsignal broke steering column won't come a
« Reply #7 on: October 05, 2006, 08:39:37 PM »
Thanks Jason
Found the problem there are 3 screws in the backside holding the halves together (found them by breaking some of the plastic section) They are not found in the instructions from  haynes or the fsm.  Oh well I can fixit with some pvc.
Jason
Offline dexetr30
  • Aloha Mr. Hand!
« Reply #8 on: October 09, 2006, 07:37:11 PM »
Quote from: "Jeffy"
None, all the parts end up smashed and leave me with nothing to work with. This solves the problem because then I don't have anything left to fix. 8)
