Author Topic: 03-06 engin to 93? ASAP!  (Read 3204 times)
Yjeep93
« on: October 09, 2006, 07:24:17 PM »
I just blew my engin and was wondering if i could put the DOC banger in replace of my original 93 4 cylinder?  help right on would be great thanx!!!
Re: 03-06 engin to 93? ASAP!
« Reply #1 on: October 09, 2006, 07:38:45 PM »
Quote from: "Yjeep93"
It won't be bolt-in by no means.  You'll need to replace the transmission, bellhousing, engine mounts, engine harness, dash harness, new ECM, gauge cluster.  You'll have to redo the exhaust and adapt it somehow.  Might have to keep the any pre-cats too.
Not to mention if it's legal in your state.  If you're going to go through all of that you might as well swap in a larger engine.
Yjeep93
« Reply #2 on: October 09, 2006, 07:42:16 PM »
i had no idea! 4cyl to new 4cyl sound pritty stright forward... now that i though about it though... am i wring?  are the newer TJ 4cyls DOHC? or are they just OHC??  and if so do i still need to do all that???
« Reply #3 on: October 09, 2006, 07:49:44 PM »
An '03-06 is not the same engine as the 1984-02.  THey are completely different engines and as such do not share much if anything.  The engines are shared with the Neon, Caravan, Liberty, Caliber, Patriot, etc...  They are all ODBII which requires a lot more then the old ODBI of your '93.  ODBII started in 1997.  Like I said before, there are a lot of things that will need to be changed to make the swap work.  Basically, replacing most of the drivetrain.
dunklervogel
« Reply #4 on: October 09, 2006, 10:57:35 PM »
If you don't want to spend much over a couple grand I suggest just ordering a new 2.5L engine...
I looked into swapping a diff engine when mine went out in my tj, and found out that basically it would take much more labor and cash than just buying another 2.5
One thing you COULD do if you wanted more power (if that is what you're looking for) is do some work to the 2.5L engine block.. like boring out.. etc.. before the mechanic installs it.  I didn't go through the trouble but I'd imagine it would be the cheapest thing to do in your situation.
Yjeep93
« Reply #5 on: October 10, 2006, 05:36:18 AM »
wow.. wel thank you all verry much for your replys!!
