Author Topic: HELP WITH MY 93's 5th  (Read 6227 times)
justin_aka_spike
« on: October 10, 2006, 04:25:44 PM »
okay weirdest thing, i didnt think it was possible until it happened, i lost my fifth gear, i was driving down the road one day, and it just went out, now i cant go over 65 in 4th with over-reving my engine, does anyone know what happened to my fifth gear, or where it went? lol :x  :cry:
« Reply #1 on: October 10, 2006, 04:30:46 PM »
There's a clip that retains the gear.  When it breaks it doesn't allow the use for 5th gear.  It's a fairly common problem when lugging the engine in 5th.  You're option would be to rebuild your existing tranny, replace it with a salvage or swap it.
justin_aka_spike
ok
« Reply #2 on: October 10, 2006, 07:10:12 PM »
thanks, i guess, i know whats wrong, now, is there a way to just get a new clip for it, and if so where can i pick one up, and how much would it cost? :twisted:
kamikaze124
« Reply #3 on: October 10, 2006, 08:18:05 PM »
I have also seen the syncronizers go out on the trannie, and that will cause you to lose a gear.. Or at least it will not go into that gear .. Has happened to me and a few others who I wheel with. It will grind really bad when you try to put it into that gear...
HIWYH8R
« Reply #4 on: October 10, 2006, 08:32:13 PM »
That happened to my tranny 3 years ago and I'm still driving it everyday, I just don't use 5th gear. No metal fileings in the fluid and no strange noises or anything. Can't use 5th anyway with bigger tires and the 2.5L
justin_aka_spike
yeah
« Reply #5 on: October 11, 2006, 12:48:09 PM »
well, its not like it grinds when i go to put it into fifth, it goes into the gear just fine, but its like im in neutral when i hit the gas, all the other gears work just fine, 2nd grinds a little, but seems to work
Re: yeah
« Reply #6 on: October 11, 2006, 12:58:27 PM »
Quote from: "justin_aka_spike"
That's the clip then.
kamikaze124
« Reply #7 on: October 11, 2006, 06:25:48 PM »
Then the clips have it folks.. Good call Jeffy. 8)
« Reply #8 on: October 11, 2006, 06:28:00 PM »
Quote from: "kamikaze124"
I've never had the problem myself but from all of the people I've been hearing it comes from lugging the engine in 5th.  It doesn't like the beating it gets from being lugged, I guess.  I'm always reving the snot out of mine, LOL!
« Reply #9 on: October 11, 2006, 10:51:30 PM »
The clip holding 5th gear on the shaft generally breaks from a hard shift from 4th to 5th and bad synchros.  I drove one for a long time after broken with no problems, but the broken clip will be in the bottom of the tranny, to heavy to really float around (but if it does) :roll:
You can replace the clip, easy to get to once the case halves are split.  It'll only do it again if the clip groove is damaged or the syncrhos are bad.
Anybody that doesn't know it, do not run the factory recommended GL5 rated gear oil in the AX5 or AX15, the high sulfer content will eat the soft brass syncrhos and your gear oil will come out like brass glitter.  If you've got hard shifting, put in Redline MT90 before it's too late.
justin_aka_spike
thanks guys
« Reply #10 on: October 12, 2006, 12:57:36 PM »
thanks a bunch guys, it really does help knowing that, anyone looking to buy a jeep? 3000 asking price
  • Poseur ExtraordinaireŽ
Re: thanks guys
« Reply #11 on: October 12, 2006, 01:17:48 PM »
Does that include a working 5th gear?? :lol:
jwrape
« Reply #12 on: October 12, 2006, 03:39:09 PM »
YJmechanic
« Reply #13 on: October 12, 2006, 03:40:11 PM »
you're giving up on the jeep just for one gear?  that's to bad.
justin_aka_spike
haha
« Reply #14 on: October 12, 2006, 05:46:43 PM »
heh,..funny, it was a joke, but im glad you have a sense of humor too
