Author Topic: loose antenna  (Read 2518 times)
mad mike
loose antenna
« on: October 16, 2006, 05:16:03 PM »
my antenna on my yj beats the snot out of the side of my jeep going down the highway i looked but see no way to tighten it up any suggestions
loose antenna
« Reply #1 on: October 16, 2006, 05:23:35 PM »
Is it the main mast of the plastic block that attaches to the Jeep?
If it's the mast, that just screws into the plastic block.  If it's teh block then that screws into the side of the Jeep.  You could be able to feel the screws up under the dash.  I think they're just sheet metal screws and not bolts though.  If it's loose then you might have to swap to bolts or else use larger dia screws.
JeepinChobot
loose antenna
« Reply #2 on: October 16, 2006, 07:13:13 PM »
Mine kept hitting my windshield mounted lights and it really annoyed me so...
I Just removed mine and stuck the whole antenna in the dash so its not touching metal for now. I plan on getting an internal antenna later but I dont use the radio much.
I'm going to weld up the whole when i get a chance but for now its sealed with a sticker. 8)
DemonicHuey
loose antenna
« Reply #3 on: October 16, 2006, 09:21:53 PM »
tennis balls???.....heck i dont even have radio.....lmao
nineinchyj
loose antenna
« Reply #4 on: October 17, 2006, 12:27:52 AM »
Is it hurting anything by flopping around?
mad mike
loose antenna
« Reply #5 on: October 17, 2006, 05:33:45 PM »
it has allready beaten the paint off in a few places but if i really get going down the highway it slaps the rearview mirror
