Author Topic: stock gear ratio  (Read 2243 times)
dan684
stock gear ratio
« on: October 17, 2006, 12:28:24 PM »
i have a 1995 Wrangler Rio Grande with a 2.5 4cyl and 3 speed auto transmission.  i am about 90% sure it has the stock gears because it is very sluggish off the line and it only has 31's on it.  is there a site or does anyone know what the stock ratio would be for this model?? there are no tags on the diffs and i dont want to fool with the turn the input, count the rotaions thing.
im getting a set of 30/35 axles that already have detroits in both and 4.11 gears but i was wondering what the stock gears were.
lanulos89
stock gear ratio
« Reply #1 on: October 17, 2006, 12:51:45 PM »
3.73's.  trust me man i feel your pain.
stock gear ratio
« Reply #2 on: October 17, 2006, 01:08:01 PM »
Your stock ratio is 3.73:1.  Check the diff tags and see if they're still there.  They are metal tags that are bolted to the diff cover.  They should have something like 3 73, 4 11, 3 54, etc.  4.10/4.11's should be a nice gain with 31's.
dan684
yeah
« Reply #3 on: October 17, 2006, 01:25:58 PM »
well im going to 33s but just for wheelin.  im gonna keep the 31s and stock rims for street use.  EVENTUALLY i wont need street tires since this will be a trail-only rig when i get my wife a new car
Re: yeah
« Reply #4 on: October 17, 2006, 01:32:53 PM »
Quote from: "dan684"
Well check out the Gearing chart in the FAQ for a better idea if what gears to get.
dan684
chart
« Reply #5 on: October 17, 2006, 02:10:24 PM »
well that chart answerd my first question
Why didnt it come up when i searced for "stock gears"?
oh well
if i was paying for this stuff i would want 4.88 gears but i wont be keeping the 30/35 axles for long and this guy is swapping his and said i could have the old ones.  and since i have stock gears and no lockers,now i can have some fun until i go for an axle swap and some 36 or 37's
Re: chart
« Reply #6 on: October 17, 2006, 02:32:31 PM »
oh well
The way you're doing it, swapping complete axles it the better way of regearing on the cheap since stock axles are fairly common.  Not to mention a lot cheaper then to regear.
Tall Boy
stock gear ratio
« Reply #7 on: October 17, 2006, 04:53:13 PM »
I GOT A 2001 DANA 35 WITH 4:10'S SITTING IN MY BACK YARD I SWAPPED IT FOR ANOTHER 35 WITH AN ARB IN IT. I WAS GONNA KEEP THE AXLES THOUGH IN CASE OF BREAKAGE.
