Author Topic: Lost 5th...  (Read 3429 times)
chrisjpeters
Lost 5th...
« on: October 27, 2006, 02:01:49 AM »
One day I was drive and for no reason (or sound) 5th gear just vanished. All other gear work fine. Shift into 5th and it's like I got 2 nuetrals. No noise from the trany at all but 5th is gone. Anybody ever have this happen.
jwrape
Lost 5th...
« Reply #1 on: October 27, 2006, 06:25:44 AM »
Re: Lost 5th...
« Reply #2 on: October 27, 2006, 11:05:52 AM »
Quote from: "chrisjpeters"
Yes, a few times. Drove it like a 4spd for a long time, even had it fixed once and it broke again.  Finally installed another AX5 and, with the correct fluid, haven't had any problems.
Lost 5th...
« Reply #3 on: October 27, 2006, 01:09:21 PM »
Offline 95jeeper
Lost 5th...
« Reply #4 on: October 30, 2006, 07:59:30 PM »
Hey there had the same problem.
First started with 5th, then after a while ever gear would start to grind.
Now i have a nv3550 in my jeep and love it.
I don't recommend jumping into the converstion but it is an idea considering that most people who got the ax5 rebuild wound up doing it again and then could of used the money on the conversion.
Weigh your options before doing anything.
Oh bye the way love the conversion
95 rio grande 4" Skyjacker lift 1" shackel 33" tires, efan, 4.0TB, kn air filter, exhaust, and sound system. NV3550 conversion
jwrape
Lost 5th...
« Reply #5 on: November 01, 2006, 11:47:28 AM »
Quote from: "95jeeper"
Yea, my main thought was, the rebuild was gonna cost $1500 for just the rebuild. My total conversion WITH a USED tranny was $800. It was a no brainer to me and now I am not hesitant to beat on the Jeep worrying about the ol ax5
Lost 5th...
« Reply #6 on: November 01, 2006, 12:20:19 PM »
From what I've heard, getting it rebuilt or a rebuild might not last that long depending on the quality of the rebuild.  I've heard more then a few cases where someone gets it rebuilt and it breaks on then again.
If that's the case then it would be better to get a used tranny out of a late model TJ which hasn't been touched.  You could even switch over to an external slave if you don't have one already.
Otherwise, the NV3550 is probably the best bet and allow you to do an engine swap later.  Same goes for a NV4500.
jwrape
Lost 5th...
« Reply #7 on: November 01, 2006, 12:29:07 PM »
Quote from: "Jeffy"
EXACTLY! Mine had already been rebuilt about 47k miles ago before I bought it. I was driving home from Florida to Georgia and about 100 miles back towards home I left a gas station and chirped the tires in first. About 20 miles later I lost every gear but 4th. I drove the rest of the I guess 400 miles to Lawrenceville, GA in 4th gear only. I only stopped for gas and prayed the whole way that I wouldn't lose 4th.
When I got it apar the insde of the tranny was gernaded inside. It would have cost me so much to replace all those gears, seals and bearings it was better to start over. Ever shop I called said $1500 and althought it would come with a warrantee for a year they said it would prolly let go again because the gears are weak. And those gears are AT least $75 each depending upon which one and I already counted 4 that were missing teeth.
Before I decided to do the conversion I asked on all the 4 forums I subscribe to about how many miles they have on their rebuilt AX5.
I got response anywhere from 5k to 128k miles. Most had let go in the lower miles like mine around 40-50k after rebuild, some where still going after 100k. It's a crap shoot on which one you will get. So I went for the sure thing and did the conversion.
Good luck with what ever choice you make.
It just makes sense to put in a stronger tranny if you plan on keeping the jeep longer than a year.
mud4feet
Lost 5th...
« Reply #8 on: November 04, 2006, 09:44:09 AM »
If I ever use 5th again, I'll let you know! :lol:
'03, 2.4, lots of mountain driving, basically a 4spd,
mud
