Author Topic: steering problem  (Read 3783 times)
4X4DAVE
steering problem
« on: November 03, 2006, 11:58:12 AM »
About a week later after installing the engine mounts, one inch lifts, something went wrong with my steering. Not sure if related. When I try to turn its really hard then easy then hard again. It seem harder to turn left. The steering fluid level is good. Could my power steering pump be going out? What should I check, and how. I think that its getting worse over time.
Thanks
Re: steering problem
« Reply #1 on: November 03, 2006, 12:46:38 PM »
Quote from: "4X4DAVE"
Thanks
Well, I'd first check the arms for any bends.  Take the steering stabilizer off and try driving it.  It could be that the stabilizer is damaged. In which case it would be a cheap fix.
4X4DAVE
steering problem
« Reply #2 on: November 03, 2006, 02:00:52 PM »
I will look tonight and hopefully a cheap fix, thanks
YJmechanic
steering problem
« Reply #3 on: November 03, 2006, 03:09:37 PM »
good place to start jeffy,  also your gearbox may be binding internally.
4X4DAVE
steering problem
« Reply #4 on: November 06, 2006, 07:52:47 AM »
I took my steering stabalizer off and it still felt the same. So, how do I check the steering box? And would I have to replace the whole thing?
I found a power steering gearbox on ebay for $27, but it ends in 8 hours, not sure if I should get it just because I don't think I could find one cheaper. Any advice would be nice
steering problem
« Reply #5 on: November 06, 2006, 10:30:04 AM »
You can probably jack the front off the ground then turn the wheel.  Disconnect the drag-link and turn it again.  Then disconnect the steering rod at the end of the column and try turning it.  This should help you localize the problem.
YJmechanic
steering problem
« Reply #6 on: November 08, 2006, 07:15:30 PM »
jeffy is dead on.  and you won't find it cheaper than that.
SGT_Tirrell
steering problem
« Reply #7 on: November 27, 2006, 03:47:48 PM »
I had a similar problem on my old AMC and it turned out to be the steering box.  Not sure if this helps you, but it took me a while to figure it out.  I just changed the box and voila! no more binding.
