Author Topic: wife going to drive jeep and no light inside  (Read 2544 times)
christopher
« on: November 07, 2006, 08:38:40 PM »
while the wifes vehicle is in the shop her and the kids need to drive the jeep.so i thought i would get everything tip top because she will have fourteen month old in it i never bothered fixing the dome light went to fix it tonight and the fuse was missing and went to put new fuse in and the brass prong was missing from the fuse panel ?does anyone know if you can take the fuse panel off and put back the brass prongs. there is a spot that specifically says dome light. :shock:
Tall Boy
« Reply #1 on: November 07, 2006, 11:06:41 PM »
I went to auto zone and they sell an entire fuse block for $6.00. It has the brass prongs in it. i was gonna use it in my older bike but have not gotten around to it yet. Make sure to disconnec the battrey.
  i got a shelf above the dash , that is bolted to the roll bar. I put a light facing the rear and spliced it into the foot light, so I am cool.
« Reply #2 on: November 08, 2006, 11:51:13 AM »
You could either get a fuse block or just get an inline fuse and wire the interior light by itself.
Actually the stock interior lights suck, really bad.  If you want a bright light get one of those $5 universal dome lights.  It should be all clear plastic and 3x3x5 brick.  Those are really bright and work great.
Kinda weird that the prong was broken.  It's not like thy can move a lot.  To replace the prong you'd have to open the box which would be a PITA since everything is wired to it.
christopher
« Reply #3 on: November 09, 2006, 05:54:06 PM »
hey thanks for the tips. just hardwired it in and it works.you where right the light really does suck going to have to get a after market one like you discribed.  :)
Tall Boy
« Reply #4 on: November 09, 2006, 11:38:17 PM »
I chose to get the 5 dollar light at kragen or checkers or pep boys cause it has a white lens to it. I did not want mine to be so bright everyone could see inside/and blind me while i was driving, but I also wanted it to be able to be bright enough to read a map. I just screwed it into my wood shelf and spliced into the foot light, ran the wires up the windshield frame and it works great. It even fades with the door chime and works with the dimmer switch.
