Author Topic: strong gas smell  (Read 2590 times)
mad mike
strong gas smell
« on: November 08, 2006, 05:16:34 PM »
whenever i am getting on the gas coming down the interstate i can smell real strong gas smell i know i have bad gas milage (it is hard to tell my speedo and odometer does not work) but i was just wondering what everybody thought i was thinking that maybe i have a o2 sensor out but wouldnt the check engine light come on?
lanulos89
strong gas smell
« Reply #1 on: November 08, 2006, 05:25:28 PM »
whenever i get on the gas, i get a smell of gun powder, i think i have another exhaust leak somewhere but whatever.  Strong smell of gas hmm..  that happened with my dads old blazer, he ended up needing a new gas tank.
strong gas smell
« Reply #2 on: November 08, 2006, 05:30:27 PM »
You might check behind the driver rear tire.  Reach around or crawl under and the Jeep, behind the tire, in the inside of the frame should be a square boxlike skidplate with a small cylinder in it.  That's the fuel filter.  See if ti's wet there.  If it is the small rubber elbow that connects the fuel filter to the fuel hardline probably has a crack in it and it leaking under pressure.
  • Poseur ExtraordinaireŽ
strong gas smell
« Reply #3 on: November 08, 2006, 05:34:13 PM »
mmmmmmmm....gas smell.....ggggrrggggggllllllllll
strong gas smell
« Reply #4 on: November 08, 2006, 05:45:11 PM »
Quote from: "Mozman68"
mad mike
strong gas smell
« Reply #5 on: November 19, 2006, 03:35:50 PM »
i tried the beano first it didnt help after removing the filter skid plate i found i had a crack right down the side of the filter     thanks again guys
