Author Topic: Toyota axles in a YJ??  (Read 3122 times)
dan684
« on: November 30, 2006, 08:15:18 PM »
Looking for and upgrade for my 35 and im yhinking about a toyota rear end.  has anyone done this or know anything about toyota axles??  would this be a reasonable swap?? it out of a 95 toyota 2wd i think.  they are about 58"-58 1/2" wide so they are pretty close to the width of the 35.
Re: Toyota axles in a YJ??
« Reply #1 on: November 30, 2006, 08:21:59 PM »
Quote from: "dan684"
Here's a starter:
http://www.4bangerjp.com/forums/viewtopic.php?t=254
dan684
toy axle
« Reply #2 on: December 04, 2006, 09:01:48 PM »
well i found a toyota 8" IFS Rear that has 4.10 gears and is 58" wide for $100.
Does this sound like a goos deal?  How much do these axles usually sell for?
Also are the spring peches anywhere close to matching or will I definitely have to relocate them for proper pinion angle?
Re: toy axle
« Reply #3 on: December 04, 2006, 09:56:12 PM »
What is the axle from, Tacoma, 2wd, etc...  I'd say the price is right depending on what it came out of.
« Reply #4 on: December 05, 2006, 07:25:18 PM »
only thing is your going foreign.
« Reply #5 on: December 05, 2006, 07:56:45 PM »
Quote from: "chardrc"
 :roll:   Ever look where you Jeep was made?  It isn't where you think...
« Reply #6 on: December 06, 2006, 12:47:01 AM »
I had an 86 toy pickup that I beat the crap out of and the frame broke before anything else. They're not built as cheply as you think. (other than the thin rust prone body).
dan684
« Reply #7 on: December 08, 2006, 03:54:33 PM »
im pretty sure its from a 4wd but not 100% sure. im going to ask him today also if it came from a 4-cyl or a v6 cuz i heard the v6 models had a thicker ring gear
« Reply #8 on: December 08, 2006, 04:51:46 PM »
Depending on which Toy 8" you get, the R&P size will vary.  I believe there are three types.  The Basic Toy 8's, the V6/Turbo and the Tacoma.  Some parts aren't interchangeable.  I believe shafts are though.  So you cna swap from 6 on 5.5" to 5 on 4.5" if you wanted to.  Lockers will be dependent on the axle also.
dan684
« Reply #9 on: December 08, 2006, 07:52:09 PM »
i was wondering if i could swap axles from a 2wd version that was 5 on 4.5 to match my d30 until i can get a 44 for the front
