Author Topic: Fuel Filler Question (HELP!!!)  (Read 1531 times)
BigBoi
« on: January 12, 2007, 07:50:05 AM »
Hey folks,
Here's the situation:
My Jeep is still new to me (month and a half) and I just had it safetied before I started driving it. It's a 97 TJ 4.0L (Still love you guys though!). I went out with it on Wednesday night and right before I drove it home, I filled it with gas. I over-filled it a little, basically, after it clicked, I still added about another 1.50$. Then I drove it straight home which is a block. Last night I went to my underground garage and it reaked of gas. I could see that it had leaked a little right under the gas tank. I took it out, drove it for about 10KMs and then parked it underground again, facing the opposite way as to see if it leaked again. I checked 3 hours later and the ground was dry.
My question is, does a Jeep overflow to the ground if I overfill it? Or do I have some rotten tube hooked into the top side of the tank that is leaking? Any input is welcome! Thanks!
« Reply #1 on: January 12, 2007, 12:46:45 PM »
There shouldn't be any leaking unless it's from the neck of the filler.  It could be leaking from the top of the tank too.  There is a seal there where the fuel filter/regulator is.  My guess is that it's not leaking from the fuel line to the engine since the engine runs and you're not getting a leak all the time.  If it's at the top it will only leak when it's full so it might be hard to find.  The other thing is a 97 is ODBII which has a take pressure sensor.  So it can tell if the gas cap if off.
Is it leaking form the center or one of the sides?  Can you even tell?  Try taking a flashlight and see if you can see the top of the tank from the wheelwell.
BigBoi
« Reply #2 on: January 12, 2007, 01:07:23 PM »
Quote from: "Jeffy"
Will do. I'll report back. Thanks bro.
