Author Topic: Changing 5th gear.  (Read 2230 times)
6099
Changing 5th gear.
« on: February 12, 2007, 09:14:18 PM »
AX5 have a 0.85 5th gear ratio.
Will AX15's 0.79 ratio gear fit?
Or even use a lower than 0.85 5th gear from a toyota gearbox?
Looking for ways to lower revs on 5th gear.
Re: Changing 5th gear.
« Reply #1 on: February 12, 2007, 09:28:50 PM »
Toyota R150F & R151F, R154, Isuzu AR5 and the GM MA5 5-speeds all have the same case and are interchangeable to some extent.  The AX-5 is not.  Swap to an AX-15, NV3550 or an NV4500.
« Last Edit: February 12, 2007, 09:30:24 PM by Jeffy »
wrangler387
« Reply #2 on: February 13, 2007, 09:05:25 PM »
^ i think he is wanting to put a ax-15 5th gear into his ax5...
« Reply #3 on: February 13, 2007, 11:26:08 PM »
When I said 'interchangable' I meant internals.
