Author Topic: YJ Rough Country 4" lift  (Read 2537 times)
TheBrain
« on: February 18, 2007, 08:37:17 PM »
Whose running or has run it and what can I expect from it?
Re: YJ Rough Country 4" lift
« Reply #1 on: February 18, 2007, 08:38:59 PM »
A rough ride!  :roflol:
It's better to spend a bit more and buy a decent lift then to cheap out and regret it.
« Reply #2 on: February 18, 2007, 08:43:22 PM »
Better off getting some BDS springs in my opinion.
TheBrain
« Reply #3 on: February 18, 2007, 08:44:37 PM »
Wow, is it really that rough?
TheBrain
« Reply #4 on: February 25, 2007, 09:20:04 AM »
I got the lift on after a couple of broken bolts and stuck bolts.  It looks great and doesn't ride as rough as the stock springs did.  Of course they had 184,000 miles on them and were pretty much flat and riding on the bumpstops.
TheBrain
« Reply #5 on: February 25, 2007, 12:19:13 PM »
TheBrain
Well if they were riding on the bumpstops then that explains why the new leafs seem to ride smoother.  Stock springs should be fairly soft since the spring rates are lower.  I'd recommend removing the rear trackbar and possibly the front.  Those leafs are fairly stiff and removing the rear trackbar should make a HUGE difference. (Removing the front can cause some bumpsteer but shouldn't be a problem with new leafs.  Also, make sure you don't overtorque the shackle bolts.
