Author Topic: body lift questions  (Read 11578 times)
jeepfourlow
body lift questions
« on: August 23, 2005, 05:28:49 PM »
So i installed a 1" daystar body mount lift and now when i shift to 2nd the shifter is hitting the seat...is there anyway to correct this? Also, i was thinking about getting the B&M Ripper shifter, would i have more complications if i did get it? thanks for any help.
body lift questions
« Reply #1 on: August 23, 2005, 07:11:55 PM »
You could take the stick off and bend it for clearance.  Probably run into similar problems with the B&M.
body lift questions
« Reply #2 on: August 24, 2005, 02:26:55 PM »
The B&M should cure the problem as it has a lot shorter throw.  But then again I need to bend my B&M shifter to get it right.  Got mine off Ebay so it was likely bent before I bought it.
jeepfourlow
body lift questions
« Reply #3 on: August 24, 2005, 04:47:52 PM »
hey is the shorter throw noticeable over stock?
body lift questions
« Reply #4 on: August 24, 2005, 09:40:45 PM »
Very, it's a very tight pattern.
Mine is a 1" spacer for the shifter base, and a stainless steel shift lever.
jeepfourlow
body lift questions
« Reply #5 on: August 24, 2005, 11:02:37 PM »
whats the 1" spacer for?
jeepfourlow
body lift questions
« Reply #6 on: August 24, 2005, 11:02:59 PM »
sorry but im a newb
YJmechanic
body lift questions
« Reply #7 on: August 27, 2005, 02:11:08 PM »
The B&M ripper is very tight comparison to stock. It should work without modification.  I have a 3" body lift and the ripper shifter and I have no problems with clearance issues.
body lift questions
« Reply #8 on: August 27, 2005, 10:37:06 PM »
Hmm, maybe I'll have to consider one of these.  I lose a lot of power shifting to 5th because of the length of the throw.  The stock setup is pretty good for a 5000 RPM powershift  through the lower gears though.
