Author Topic: Caster YJ's Dana30  (Read 9515 times)
Tappie
Caster YJ's Dana30
« on: August 25, 2005, 03:21:58 PM »
Hi,
I'm busy putting my YJ on SOA. The rear axle is in place, and now i'm working on the front axle. I found out that the axle has to sit back 6-8 degrees (stock). Can anyone tell me if I put the diff yoke horizontally, will the caster be around 7 degrees? (is caster allready in the axle?). Or do i need to put the yoke in a certain angle? I can't mesure it in the stock setup and copy it, don't have the stock leaves anymore....  :?
Thanks,
Charon
Caster YJ's Dana30
« Reply #1 on: August 25, 2005, 09:40:57 PM »
I'd just make the new perches parallel to the old ones.  Makes it easy.
ratherbejeeping
Caster YJ's Dana30
« Reply #2 on: August 26, 2005, 09:08:15 AM »
Quote from: "Jeffy"
What he said.  I've done a bunch of these and never had an issue.
shotgun
Caster YJ's Dana30
« Reply #3 on: August 26, 2005, 01:50:41 PM »
you left the stock perches on there? I reused mine. we put a magnetic angle finder on the steering knuckle to find the angle. Somewhere near the ball joint we found a flat enough spot.
