Welcome to 4BangerJP.com... Registration isn't working properly... Anyone who hasn't activated their account, please create a new one. Thanks!
0 Members and 23 Guests are viewing this topic.
ive also noticed that my my front driveshaft is totaly free in 2wd. when a customer had me look at there 01 tj the front driveshaft and axles were always engaged even in 2wd except the transfer case isnt lock'd.
Jesus, it seems that everyone's mpg's keep going UP and mine keep going DOWN! I guess I'mm adding all the wrong parts for mpg... BUT, then again the Jeep is no t a daily driver, so I ratehr go for power than mpg now. Still, I know there is room to improve, as I can still smell a faint gasoline smell when I fill up the tank, so I'm sure there is a small leak SOMEWHERE above the tank (already tried twice to lower it and fix it, but no luck so far! At least it's a very FAINT SMELL, and no liquid is seen spilling; it's only fumes coming out if you ask me, and you can only smell it if I park the Jeep in the garage and stick your nose in the fenderwell behind the DS rear wheel.)
If you can smell it in the fender well then it's probably the 90* rubber tube on the fuel filter.
Buy new breather line and replace them completely. Otherwise, cut and re insert.
tires make a big difference on fuel mileage. My non winter tires are toyo open country's. winter tires are firestone winterforces. with the winter force i was down to only 16mpg city or highway. also I run 5w-30 motor oil. lighter engine oil can slightly improve fuel mileage as well. 5w-30 is all i ever ran. using a 10-30 or 10-40 i wouldn't actually know how much of a difference it would make fuel mileage wise. but once i poured a whole bottle of STP in my subaru and that really slow'd the engine down. least it toke care of a bad valve tap in that motor til i sold it.
