Author Topic: HELP  (Read 2470 times)
kenny kustom
HELP
« on: March 15, 2007, 06:47:22 PM »
I'm about at my wits end on this one. Here's the story. I have a 1989 yj with a 94 2.5L with about 20k on it. I put on the Avenger Supercharger. Ran ok. I put in the Split Second Air/Fuel/Timing FTC1 computer with a bas map to get me going. Ran better. I took the jeep to a performance shop to tune it on the dyno. Ran GREAT. About a month later, it started getting harder to start. Longer crank times and a rougher, sputtering idle. Still ran good under load. Then it got worse, it would stall going around corners at idle, and would sputter, high idle and stall at a standstill.
After it would stall, i would have to wait about 5 min, then it would restart, otherwise if i didnt wait it would just crank.
So i started throwing parts at it. Performance Dist. Firepower kit ( cap, coil, rotor, plugs, wires ) Better idle but still stall. Then i found the crank sensor had melted to the downpipe. Replaced. Still problems. It doesnt stall, but it idles at 1k and under load it pops and sputters quite often... ANY IDEAS BEFORE I BURN IT ? ??
Re: HELP
« Reply #1 on: March 15, 2007, 07:29:16 PM »
man alot of people our having problems with their 4bangers recently :'(... hope you can find the problem before it burns up.
dunklervogel
Re: HELP
« Reply #2 on: March 15, 2007, 07:30:48 PM »
Always kinda wondered if modifying a stock engine lowered its useful life.  Maybe it's true  :uhoh:
Tall Boy
Re: HELP
« Reply #3 on: March 15, 2007, 08:20:50 PM »
it's pro bably your intake somehow/where. supercharger is not my can of beer yet.
/dev/null
Re: HELP
« Reply #4 on: March 15, 2007, 10:10:52 PM »
How's the fuel pressure? Pump or filter clog, maybe....
Vacumn line went(melted) along with the crank sensor?
Check the o2 sensor as well. If it's fried, your computer is getting faulty info for setting the fuel air mix.
:puzzled: :puzzled:
I know, I'm just thowing things out here... Maybe one might get you going in the right direction.
Peter M
Tall Boy
Re: HELP
« Reply #5 on: March 16, 2007, 12:15:10 AM »
Take it to the dealer to run a diagnostic on it.
Re: HELP
« Reply #6 on: March 16, 2007, 12:30:04 PM »
Hmmm, at idle you should be running little to no boost so that shouldn't be effecting anything.  A high idle would lead to be look for a vacuum leak someplace OR perhaps, the engine isn't getting enough gas. Although you have a wide band O2 sensor on there right?  How's the fuel pump sound?  Have you checked the fuel rail pressure at the Schrader valve?  Have you timed the engine?
kenny kustom
Re: HELP
« Reply #7 on: March 16, 2007, 03:20:12 PM »
o2 sensor and leaky intake gasket between the blower and the intake manifold. The computer couldnt make up for all the extra air being sucked in.
Re: HELP
« Reply #8 on: March 16, 2007, 05:05:57 PM »
so you found the problem and fixed it.  :puzzled: :beers:
kenny kustom
Re: HELP
« Reply #9 on: March 16, 2007, 07:31:09 PM »
I found the problem. Now i just need to find the time to fix it. I have to remove the whole blower to get at the stupid gasket.... :brick:
Tall Boy
Re: HELP
« Reply #10 on: March 16, 2007, 09:21:34 PM »
Cool, you found out where it was leaking. Most of the work is done then and you got all weekend to toy with it.
lanulos89
Re: HELP
« Reply #11 on: March 17, 2007, 02:08:34 AM »
i was thinking about my intake gasket, i used the crappy paper gasket when i did my header so i wouldnt be surprised at all. ill chekc on that when the snow and ice stops and it gets alittle warmer out
