Author Topic: squirrelly brakes  (Read 1679 times)
huntingbuck101
squirrelly brakes
« on: March 23, 2007, 08:16:24 PM »
Just got my new motor, lift and 33 installed this week and drove it home tonight for the first time with them.
I had a car pull out in front of me when I was doing 60 and then he decided to turn off about 1/8 mile later.
Any way when I hit the brakes the jeep was all over my lane. I have only put on around 100 miles since I bought it I can't say for sure if it would have done that when it was stock but I don't think it would have. I need to get it fix. I relay wasn't braking that hard and I would hate to see what would happen if I had brake harder.
Re: squirrelly brakes
« Reply #1 on: March 23, 2007, 10:09:41 PM »
Sounds like bumpsteer.
lanulos89
« Reply #2 on: March 23, 2007, 11:11:38 PM »
steering stabilizer still good???  maybe time for an upgrade
huntingbuck101
« Reply #3 on: March 24, 2007, 09:32:09 AM »
I'm thinking I have a sticky brake cylinder. the other day with the lift in and stock tires I braked on a dirt road and it put me to left  really bad. I also noticed before that the jeep was was pulling to the right while driving straight. when I got home I smelt something hot and it was my front right brake. the brake was sticking and I could barley rotate the tire when jacked up. so I pound on the caliper with a rubber mallet and it seem to free up. when I got to work yesterday I took of the caliper and cleaned it with a wire brush.
But since it still pulls left I think I might need to replace the caliper. also since the lift I haven't had it aliened yet (still go down the road straight) nor did I do any drop brackets with the 2 1/4 lift and with 163000 on the stock stabilizer it could be a bit of all of the above.
« Reply #4 on: March 24, 2007, 11:58:17 AM »
Well, it's time to replace those calipers then.  Might a well do both.  Reman. calipers are cheap.  Usually under $20 each.
Offline SKI BOY
« Reply #5 on: March 25, 2007, 09:11:55 AM »
Check your rotor, it may have warped if it was over heated too much!!
Ski Boy
huntingbuck101
« Reply #6 on: March 26, 2007, 06:18:21 PM »
Yep, it was the caliper replaced both and turned rotors. stops straight now.
