Author Topic: Blood, sweat & gears!  (Read 3997 times)
might4banger
« on: April 01, 2007, 08:44:07 PM »
Well I got motivated!
I tore into the rear axle first... Got the everything apart. The big PITA was pulling the old carrier bearings off...
Made a trip to Harbor freight this morning - and pick up a split bearing puller. Even with it the carriers did not want to budge - hit 'em a few times with the air hamer. Then cut a slit in 'em with the dremel. One popped right off the other broke. A few more tries with the puller & air hammer it came off.
I will prolly milk this for a while - I have to wait until I get some tools back from a friend to do the front. I want to replace the front axle U-joints while I swap gears.
Still need to set up the new stuff in the rear. Just glad to get it all apart w/o much drama.  :thumbsup:
Chad
Re: Blood, sweat & gears!
« Reply #1 on: April 02, 2007, 06:03:02 AM »
Good luck sounds like you got a good start going
« Reply #2 on: April 02, 2007, 10:36:54 AM »
might4banger
« Reply #3 on: April 03, 2007, 05:59:52 PM »
Chapter 2 - or how to install new carrier bearings.
Literally a hot tip.
Put the new carrier bearings in the oven and heat to 400 deg.
Did not need a press to install them -- just a few light hits and they are on.
Need to mount the new pinion bearing for a test fit. The tolerences here seem tighter so - I am going to put the pinion in the freezer and heat the bearing to 400. Going to have to wait on this one... prolly won't get to it until thursday... Got to work late tomorrow.
might4banger
« Reply #4 on: April 03, 2007, 07:56:05 PM »
Hehe - The wife was going to bake a cake and already had the oven hot. I already had the pinion in the freezer so I could not resist temptation... Pinion shim and bearing INSTALLED!  :naughty:
Whadda ya mean the cake tastes like 80W90 !!!  :pot:
I'll be checking patterns soon... nice jump start.
To this point - with a good set of tools, air compressor and this:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93980
You can do your own gears.
« Reply #5 on: April 03, 2007, 09:18:40 PM »
If you've got room one of these would be nice to have.  Cheap too.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=4711
might4banger
« Reply #6 on: April 04, 2007, 05:17:27 AM »
My neighbor has a 20 ton press like that...
Why buy when you can borrow! - I was surprised I got by with out a press so far.
« Reply #7 on: April 04, 2007, 06:09:45 AM »
lol we barrowed a 20 pound one of those ounce at our local auto parts store and they just gave it to use cuz they couldn't figure out how to use it..  :roflol:
Enjoi
« Reply #8 on: April 06, 2007, 01:14:08 PM »
hehe a 20 pound press? what you going to use that for? mashing potatoes?
« Reply #9 on: April 06, 2007, 04:45:52 PM »
l0l... i meant ton and appon looking at it i realized that it is actually a 30 ton press.
might4banger
« Reply #10 on: April 08, 2007, 07:26:03 AM »
The 20 pounder is for making patties for the cheeseburgers several posts above...  :twofingers:
« Reply #11 on: April 09, 2007, 12:36:11 PM »
This is the old girl that I use......
might4banger
« Reply #12 on: April 14, 2007, 09:09:37 PM »
After much delay - the rear axle is done... it sucks to do gears! Yuck! Once I got a decent pattern, I broke the cast shim for the carrier and had to start over.  :'(
Guess I'll know better for the front.  :eek:
Biggest problem was the crush sleeve and outer pinion bearing. I rigged up a piece of angle iron to the flange yoke and used a big breaker bar to seat the outer bearing... that was by far the worst part.
Gotta go it' beer thirty!  :beer:
might4banger
« Reply #13 on: April 14, 2007, 09:11:29 PM »
Almost forgot... 4.88 aand the 35's worked out pretty good ~ fells about back where it was.
 :smokes:
