Author Topic: Nitrous Oxide System 50-75 Shot on a 2.5L Auto with 37"  (Read 13378 times)
RoKnAzn
Re: Nitrous Oxide System 50-75 Shot on a 2.5L Auto with 37"
« Reply #15 on: April 06, 2007, 03:25:05 PM »
Where most of u guys from? Out West? Here are some of the pics of me wheeling.. The reason i need the extra Ump...
Got Stopped here..:(
So I backed up and Gave it a Big Bump!
Nice Chilling Pic..
Clayton
« Reply #16 on: April 06, 2007, 03:40:48 PM »
We've got plenty of stuff like that in MN.  How much pressure are you running in those tires?  Looks like too much
RoKnAzn
« Reply #17 on: April 06, 2007, 03:47:21 PM »
Driveing everyday..16psi and 9psi offroad..
« Reply #18 on: April 06, 2007, 03:50:59 PM »
Might want to try closer to 5 psi.  In the pictures it doesn't appear that there is much bulge at all in the tire, also appears that you have no locker in the front.
wrangler387
« Reply #19 on: April 06, 2007, 03:52:57 PM »
i definately would not run NOS... if you plan on using it, it is expensive and a pain to refill. if all you want is something to turn on for alittle bit more umphh... Look into using a mecedes eaton m62 supercharger, they use an a/c clutch type pulley so you could wire up a switch to manually engage and disengage it. otherwise you need a motor swap or regear.
Offline dexetr30
  • 4BangerJP.com® Donator
  • Aloha Mr. Hand!
« Reply #20 on: April 06, 2007, 03:54:39 PM »
I'm from Northeast Pennsylvania and the majority of the terrain here is the same as what you have in your pix. I've never needed more than what my little 4 banger can provide with the mods I have into it. By the way, nice flat fender kit. Poison Spyder Customs?
« Last Edit: April 06, 2007, 04:07:55 PM by Jeffy »
Offline dexetr30
  • Aloha Mr. Hand!
« Reply #21 on: April 06, 2007, 03:58:57 PM »
[hijack]^^^^ Above is a good reason to have the "edit post" option back. I don't have post accountability issues so can we please have this option back??? :whistle: [/hijack]
« Reply #22 on: April 06, 2007, 04:09:12 PM »
I've actually driven with 9psi on the highway with my MTR's.  :uhoh: They really need to be lower for a good bulge with their stiff sidewalls.
RoKnAzn
« Reply #23 on: April 06, 2007, 09:43:37 PM »
Umm..There is. :D Im running a 15x10 so that is why im not dropping down to 5psi and I have ARB front and rear.
-Anthony
« Reply #24 on: April 07, 2007, 06:08:41 AM »
-Anthony
Ah, then I would spend my money on the right sized wheels for those tires (15x8) before getting a nitrous kit.   The Arb thing makes sense, could see that both front tires were not turning in a couple pictures.
« Reply #25 on: April 07, 2007, 11:52:46 AM »
What's the actual problem, are you just getting stuck and spinning your wheels?  Or are you stalling out?
yellowta
« Reply #26 on: April 07, 2007, 01:51:20 PM »
I think the automatic is the issue. Converter slip at idle is robbing all of his torque. Try finding info about a good offroad converter with a lower stall and that thing will crawl like crazy  :smokes:
Offline Elyod
  • Sedona is red
« Reply #27 on: April 07, 2007, 06:06:41 PM »
you could also try a 4:1 transfer case kit or swap.  tera low sells them i think
« Reply #28 on: April 07, 2007, 06:47:22 PM »
For the slick snot, you need a bit of momentum to get over the lack of traction.
RoKnAzn
« Reply #29 on: April 07, 2007, 09:53:45 PM »
Is this one possible for the 2.5L I would love to do this too with NOS...:D
