Author Topic: Axles  (Read 1738 times)
4x4grey88
Axles
« on: April 14, 2007, 12:09:00 AM »
Hey I recenlty purchased a set of axles Dana 30 & 35 with 4:56 gears and Powerloc limited slip lockers.
After reading some of the comments on these axles would you recommend installing this set? I currenlty have a 2.5" lift with 33" xterrains. I dont have tire rub unless I hit the trails real hard (which I'm not really a large rock crawler Jeeper).
When I installed the 33's I noticed a big loss of power and was looking into re-gearing when I found these two axles (hub to hub) for about $400.
I was figuring that it would be less expensive this way.
Your opinion????
Re: Axles
« Reply #1 on: April 14, 2007, 01:06:48 AM »
Defiantly.  It's going to cost you at least twice that to get to the same point.  Not to mention you can swap axles in a day with just hand tools.  With air tools, it can be done in a few hours.  You can keep your old axles as spares which is a real good idea.
lanulos89
Re: Axles
« Reply #2 on: April 14, 2007, 07:17:49 AM »
do it that xactly what i just did, and i kept the shafts as spares, and im selling my gears and cariers today for 150 so yea go for it
