Author Topic: brake light  (Read 9299 times)
braves3331
brake light
« on: August 31, 2005, 07:26:49 PM »
hi ya'll i've got a 1990 jeep wrangler 2.5, and anyhow, the e-brake light doesn't go off anymore, when i take off the ebrake. anyone run into this problem or know how to fix it? thank you in advance
brake light
« Reply #1 on: August 31, 2005, 08:52:29 PM »
Check the switch at the pedal.  There should be a spring loaded switch with one wire going to it.  If the shaft of the switch is bent it will get caught up.  I'm not sure if I'd try bending it back.  BTDT and ended up breaking off the rod.
braves3331
brake light
« Reply #2 on: August 31, 2005, 09:53:05 PM »
cool i'll check that out jeffy. thanks again for your help man
brake light
« Reply #3 on: September 01, 2005, 10:58:12 AM »
Did you try pulling up on the ebrake pedal?
Could also be a brake hydraulic problem but you'd likely have other symptoms.
