Author Topic: my disc brakes?  (Read 1843 times)
officer mike
my disc brakes?
« on: May 15, 2007, 07:55:27 PM »
I have that 8.8 that has the disc brakes and my question is do I need a different master cylinder or a proportioning valve? thanks  Mike
might4banger
Re: my disc brakes?
« Reply #1 on: May 16, 2007, 06:03:29 AM »
I did not use either...
Works fine as is.
Re: my disc brakes?
« Reply #2 on: May 16, 2007, 09:40:39 AM »
You don't 'need' them, but I think some have reported improved braking with them.  I'm researching them now for my 4whl discs.  Both my YJ and MJ braked well after converting the rear to disc.
Re: my disc brakes?
« Reply #3 on: May 16, 2007, 12:33:04 PM »
I've heard pf people taking out the pill that regulates the proportioning valve to get 50/50 brake pressure with disc brakes.  You might find that you want to upgrade the master cylinder anyway though.  I'd like to eventually convert mine to hydroboost.  My brakes aren't bad but they could be better.
Re: my disc brakes?
« Reply #4 on: May 17, 2007, 08:32:05 AM »
I've done the swap with a disc brake 8.8 and didn't need anything more. Even the stock rear ds fits with a flange yoke for the axle pinion end. I still have room at the tcase for compression with the stock slip yoke.
Re: my disc brakes?
« Reply #5 on: May 17, 2007, 11:12:39 AM »
On my YJ, I removed the seal in the prop valve and replaced the master cylinder with one from a 78 mercury marquis.   Stopping power is amazing.
officer mike
Re: my disc brakes?
« Reply #6 on: May 17, 2007, 08:42:01 PM »
Thanks guys. I appreciate it
