Author Topic: Hardtop vertical storage dolly  (Read 3396 times)
4X4DAVE
« on: May 22, 2007, 04:04:31 PM »
I found plans on making a hardtop vertical storage dolly out of wood. I think that I will try this, its a lot better then buying one from Quadratec, they have them going for $139,
Here the link
http://www.jeepforum.com/forum/showthread.php?t=152881
Chad
Re: Hardtop vertical storage dolly
« Reply #1 on: May 22, 2007, 06:28:19 PM »
nice dolly  :koolaid:
  • Poseur ExtraordinaireŽ
« Reply #2 on: May 22, 2007, 07:10:04 PM »
If you have a garage to park in, why not do a ceiling mount??  Back in, crank it up with a come-along and drive out...park face in right below it.  One man operation and saves the most space IMHO. :thumb:
« Reply #3 on: May 22, 2007, 07:25:49 PM »
I use ratchet straps and hang it off my garage rafters.  I'd be a bit worried by some of those 'racks'.  I get a lot of wind through my garage with the door open.  I can just imagine it falling over...  The PVC rack some place was selling was kinda cool and simple to make.
« Reply #4 on: May 22, 2007, 07:54:05 PM »
the thing about hanging it from the rafters... well at least in my garage is that our Rubicon isn't the only vehicle we work on in our garage and it would be hard to work on another vehicle with the hard to hanging up there let alone walking around without hitting our heads on it. but it is a good idea and would work well if your garage is set up so that it will work out with out conflicts. i was actually thinking of buying my dad one for his hard top rack things for his birthday but now i might just make one.
« Reply #5 on: May 22, 2007, 08:00:07 PM »
so is warping a real concern to be worried about of will it most likely not happen.
« Reply #6 on: May 22, 2007, 08:07:37 PM »
If you stand it on end, it may warp a bit but not enough to really worry.  The tops aren't 100% prefect.  You need to push and pull them to get then aligned right, this flexes the top a little.
christopher
« Reply #7 on: May 22, 2007, 09:42:46 PM »
i put some back supports on mine and also sides so there is no way it can come out.i think i had 25 dollars in lumber. lot cheaper then the ones you can buy took about halfhour to make works like a champ .oh also 10 dollars in wheels so i can move it around.
4X4DAVE
« Reply #8 on: May 23, 2007, 08:49:24 AM »
Hanging from the ceiling of my garage is out, my garage is too small.
Check out this one, he wants $289.95 + $49.90 shipping, it doesn't look that hard to make plus I could make a place for my doors, but this would cost a lot to make. Also, I am not sure where all the weight is centered
http://www.kxstand.com/
I also found this one but he said it Didn't work, but if he used 3" PVC I could see it working, maybe?
http://www.jeepforum.com/forum/showthread.php?t=414947&highlight=hardtop+storage
« Reply #9 on: May 23, 2007, 12:08:57 PM »
That's the one I saw before.
