Author Topic: dome light question  (Read 3154 times)
huntingbuck101
dome light question
« on: June 13, 2007, 08:19:35 PM »
after taking off my hard top and putting on a soft top by dome light will not come on when I open the doors but it will with the switch. also should leaving the headlights on with the key of make a warning beep?
Re: dome light question
« Reply #1 on: June 13, 2007, 10:40:30 PM »
It sounds like you disconnected the pin switches at the doors, if they are not coming on anymore.
As for the headlights, that's a new fangled car feature, you're driving a Jeep.  :lol:
huntingbuck101
« Reply #2 on: June 14, 2007, 08:21:32 PM »
then why does my jeep beep 4 to 5 times when I start it? whats the beeper for?
« Reply #3 on: June 14, 2007, 09:44:41 PM »
Well, first it would be nice to know what kind of Jeep it is.  A Jeep like a YJ will not have a buzzer.
Liljeepz
« Reply #4 on: June 15, 2007, 02:30:08 PM »
It sounds like a TJ, Your  door switch sounds like its disconnected. I never really listen to my beeper, but I think its the seat belt reminder, Reach under your dash and feel the back of the switch, you should feel wires going to it, see if you can feel if there connected. If they are they could have gone bad or corroded.
I disconnected mine when I first bought the Jeep, I was sick of pulling the fuse every time I took my doors off like the dealership suggested. The wires are still there but I taped the ends and tucked them around some others so there out of the way.
« Reply #5 on: June 15, 2007, 05:02:06 PM »
If that's the case then it's the same as the YJ.
Offline Elyod
  • Sedona is red
« Reply #6 on: June 15, 2007, 05:34:29 PM »
I second the seat belt reminder.  Mine always beeps.
« Reply #7 on: June 15, 2007, 06:43:58 PM »
My TJ doesn't do this but I think I disconected the wires on the seatbelt buckle can't remember, as for the dome light I just added a switch so I can disconect power to them when the doors are off.
Chad
« Reply #8 on: June 16, 2007, 02:27:45 PM »
i just removed the fuse so my dome light will onlyturn on if i turn it on manually at the headlights that way when the doors are off my dome light does not stay on perhaps its just a fuse
Liljeepz
« Reply #9 on: June 17, 2007, 08:29:40 AM »
Do you have a TJ and what year is it, if I remember correctly, and I could be wrong, but I thought when I pulled my fuse out my lights would not work at all in mine.
I'm going to have to go out and see if I'm wright or wrong.
