Author Topic: Engine Mounts  (Read 1970 times)
Bluesteel88
Engine Mounts
« on: June 16, 2007, 03:20:06 PM »
Just noticed recently that on my engine mounts (stock i believe) the engine is pulling out the rubber backwards towards the firewall about a good inch or 2. I have a motor mount lift 1in jks. Was just wondering if thats a sign for new engine mounts or some other problem causing the engine to pull out and back like that?
Thanks
Re: Engine Mounts
« Reply #1 on: June 16, 2007, 03:27:37 PM »
I wouldn't worry about them unless they are torn.  Although you could relax the tension on the rubber by adjusting all of the engine and transmission mounts.  This is a PITA with one person though.
Bluesteel88
Re: Engine Mounts
« Reply #2 on: June 16, 2007, 03:57:08 PM »
Okay, thanks alot. wasn't really sure if it was a bad sign lol
Re: Engine Mounts
« Reply #3 on: June 16, 2007, 06:43:21 PM »
It just means the engine shifted a bit with the new mounts.  Really you'd want the bushings to be neutral, which you can do by moving the whole drivetrain rearward a bit.  Unless they're broken or torn you should be OK though.
